Oil leaking from under carriage! - BMW Forum - BimmerWerkz.com
Old 09-09-2004, 01:22 PM   #1 (permalink)
quality
Delmarco's Avatar
Thumbs up
I noticed this morning that they were tiny ( quarter & nickle sized) spots of oil under the front of the car. Never seen this before and the car was sitting for full day and night. When I looked under the car (see pics below) I noticed some parts of the under carriage were saturated with wet oil that came right off on my finger tips. I have no idea what I'm looking at used (see pics) nor whether I should call a BMW mechanic.
Has anyone experienced this before?
My car is a 1995 318i. I'm due in about 20-30 days for oil servicing.
Thanks
Old 09-09-2004, 01:26 PM   #2 (permalink)
quality
Delmarco's Avatar
another picture
Old 09-09-2004, 01:38 PM   #3 (permalink)
Sk1d's Avatar
Sk1d is an unknown quantity at this point
Might want 2 take a quick look under the hood 2 see if u can trace the source of the leak. Looks quite dark so i'm guessing its engine oil and not power steering fluid. I've had a valve cover gasket leak bad before, but u really need 2 find out where the leak starts...
Me-Chanic
Sk1d is offline   Reply With Quote
Old 09-09-2004, 02:11 PM   #4 (permalink)
BLACKBMW's Avatar
BLACKBMW is an unknown quantity at this point
Problem! And I'm no mechanic
I would check hoses first, then check around the oil pan
If the car is smoking from the exhaust then you really have a problem
Sorry I cant help more but good luck
J...
<img src='http://img.photobucket.com/albums/v629/BLACKBMW1/alssig.jpg' border='0' alt='user posted image' />
Thought for the day: &quot;d'uh&quot;
BLACKBMW is offline   Reply With Quote
Old 09-09-2004, 04:23 PM   #5 (permalink)
thekid's Avatar
If you can get underneath the car, then spray it with a cleaner to get all of the oil off and then turn the car on and let it run for about 30 mins (assuming your cooling system works well) or you can leave it off but it usually takes longer. And watch for the first signs of oil coming down, then it is easy to trace. When it is covered with oil like that it is almost impossible to tell where it is coming from.
Old 09-09-2004, 04:29 PM   #6 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Negetive on the oil theory.... if that is sitting directly on your power steering rack.. I'd venture to say that is power steering fluid coming from one of your power steering lines... either the one from the pump to the rack.. or from the rack to the container.. or from the container to the pump. Its one of the three.. very common problem with E36s...
Just an idea...
Les
1997 E36 M3 1990 E30 325i
Old 09-09-2004, 07:06 PM   #7 (permalink)
quality
Delmarco's Avatar
Just an idea...
Les
How much am I looking to pay for that?
Power steering fluid leaking sounds more expensive to fix than an oil leak.
Thanks ya'll.
Old 09-09-2004, 07:16 PM   #8 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
a powersteering leak isnt THAT horrible.. you can live with it and refill the resevoir when it gets low. at least until you can afford to fix it. and if its the lines im assuming its not expensive to fix.
catalyst. is offline   Reply With Quote
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
Help< Finally Figured Out Where Coolant Is Leaking BMW-ATI 3-Series (E36) 19 09-08-2008 07:15 PM
