Oil Leaking?? - BMW Forum - BimmerWerkz.com
Old 11-17-2004, 05:45 PM   #1 (permalink)
ayyado's Avatar
ayyado is an unknown quantity at this point
there's oil leaking from the side of where the engine cover is it drops on top of the metals and it burns i will post pic soon....... can any one tell me how to fix this witout seekin a mechanic
Thanks
<img src='http://www.geocities.com/ayyado/M5.jpg' border='0' alt='user posted image' />
ayyado is offline   Reply With Quote
Old 11-17-2004, 05:49 PM   #2 (permalink)
Speedy-325is's Avatar
tighten the bolts up a little bit. if i am thinking of the spot u mean right.
if not, we're gonna need a photo
Old 11-17-2004, 05:51 PM   #3 (permalink)
quality
Delmarco's Avatar
Get a photo up....I've learned alot about leaks recently...but it sounds like your BMW dealer or Mechanic is about to get a fat X-Mas bonus out you...cha-ching.....sorry dude!
Old 11-18-2004, 11:39 AM   #4 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
kestrel325is is an unknown quantity at this point
From the sound of it, you need to replace the valve cover gasket. They're pretty cheap (~$35) and it takes about 30 minutes to do.
kestrel325is is offline   Reply With Quote
Old 11-21-2004, 01:04 AM   #5 (permalink)
ayyado's Avatar
[attachmentid=15289][attachmentid=15290]
got the pics leak is from under the black cover ??
Old 11-21-2004, 05:56 AM   #6 (permalink)
llzoom_zoomll is an unknown quantity at this point
Send a message via AIM to llzoom_zoomll
looks to be most likely, the valve cover gasket. you can replace it, as stated above by kestrel. about $35. if you want, you can tighten up the bolts around it for now (not too tight) and clean it with engine degreaser to make sure all the oil drips down. then check for the exact leak point.
good luck bro
You think gas is expensive? CHECK THIS OUT:
Lipton Ice Tea 16 oz $1.19 ...........$9.52 per gallon
Ocean Spray 16 oz $1.25 .......... $10.00 per gallon
Gatorade 20 oz $1.59 ..... $10.17 per gallon
Diet Snapple 16 oz $1.29 .......... $10.32 per gallon
Evian water9 oz $1.49..........$21.19 per gallon?
Brake Fluid 12 oz $3.15 ........... $33.60 per gallon
Pepto Bismol 4 oz $3.85 ........ $123.20 per gallon
Vick's Nyquil 6 oz $8.35 .... $178.13 per gallon
llzoom_zoomll is offline   Reply With Quote
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
Help< Finally Figured Out Where Coolant Is Leaking BMW-ATI 3-Series (E36) 19 09-08-2008 07:15 PM
