oil leak - please help! - BMW Forum - BimmerWerkz.com
Old 01-09-2011, 02:44 PM   #1 (permalink)
harobe is on a distinguished road
I have a 1995 325i with an oil leak somewhere on the drivers side. The oil drops off a metal piece not directly from the block.
Lately, I realized that it is real bad when I first start the car & not so bad once warmed up. It seems a gasket expands & the leak diminishes.
What is on the drivers side that can leak?
Thanks for your help!
harobe is offline   Reply With Quote
Old 01-09-2011, 03:08 PM   #2 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Can you point out, where on the driver's side using the pic below:
Old 01-09-2011, 03:32 PM   #3 (permalink)
It is about where the brace holds up the motor.
Old 01-09-2011, 05:41 PM   #4 (permalink)
that looks like it could be the oil pan gasket.......# 8 in link below:
RealOEM.com BMW E36 325i OIL PAN/OIL LEVEL INDICATOR
jbg
Old 01-10-2011, 10:44 AM   #5 (permalink)
If that is the problem, how difficult is that to change?
Old 01-10-2011, 11:36 AM   #6 (permalink)
Be sure it is leaking between the oil pan & engine block, you will see seepage & wetness on the oil pan.
Pelican Technical Article: BMW Oil Pan Gasket Replacement
Old 01-12-2011, 06:01 PM   #7 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 84 325e
Clean of engine with a few cans of brake clean and drive car for a day or 2. Look for highest point. If it is a pretty good oil leak I would check the oil filter housing, otherwise may be valve cover gasket, or oil pan.
Oil Leak??? PhantomE28 5-Series (E12,E28, E34, E39, E60) 4 10-26-2010 02:10 PM
air leak ponsford26 3-Series (E46, E90) 1 10-14-2009 12:49 PM
Need Help w/Oil Leak Sketchy1985E30 3-Series (E21, E30) 3 05-28-2009 08:30 PM
Bmw 318 Oil Leak nobrakese36 3-Series (E36) 5 07-14-2005 01:58 PM
oil leak Old_School_Bimmer 3-Series (E21, E30) 1 07-26-2004 01:09 AM
