Oil Leak By Filter Housing. Wtf?? - BMW Forum - BimmerWerkz.com
Old 03-07-2005, 06:17 PM   #1 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
Hey, I researched the forum on this, but could not find enough information on it.
My oil filter housing is leaking form the rear, right on top of where the vanos oil pipe is bolted on.
It seems to be leaking from a metal plug on the rear of the oil filter housing.
Ive heard this can happen.
How do i fix this? Do i need a whole new oil filter housing? This is like 430 bucks for the part,, and i really dont want to spend this.
Is there a way to fix the leak by the plug?? How long can i use the car, i mean will it only leak slowly, or it can burst and let a lot of oil out???
Please help me..... THnaks
You are a BMW driver when you become part of the "Ultimate Driving Machine"
Fraude an Fahren
BMW > Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Old 03-07-2005, 06:57 PM   #2 (permalink)
fushuman is an unknown quantity at this point
HOLLY SHIT!!!!!!
I have the same problem, same leak (mine's below the oil filter housing), maybe even in the same spot!!!! And i've searched as you have but no luck.
Well this leak is visible and it seems is only happens when i start the car in the mornings and it leaks for less than a minute.
i was thinking of fixing it (got the gaskets for it) but haven't done it yet. for my car, 318, I must remove the alternator in order to remove the housing and change the gaskets.
So don't buy the housing check the gaskets for the housing, I went to www.realoem.com it shows great diagrams of the entire car as far as "everything". thats how i found out there was a gasket for the oil filter housing.
If you're gonna fix it please let my know thru this topic how it went, I've just been adding some oil every week and had this for over a month, nothing has burst or anything.
<img src='http://www.bmw-forums.com/forum/uploads/photo-7050.jpg' border='0' alt='user posted image' />
CONQUER THE WORLD WITH YOUR <span style='color:red'>HEART</span>!!!!!
CONQUER THE RACE WITH YOUR <span style='color:blue'>SOUL</span>!!!!
fushuman is offline   Reply With Quote
Old 03-07-2005, 07:00 PM   #3 (permalink)
or it could be the oil level sensor, which is a plug near the housing, check that too
Old 03-07-2005, 08:00 PM   #4 (permalink)
Car: 1993 325i
[snapback]305989[/snapback]
yeah
I looked from the top of the engine then from the bottom and clearly the oil wetnees i see around the engine is comming from the housing.
I checked the oil pressure switch, no leaks there,
and on the vanos pressure oil line, there are no leaks there.
the only place i saw that leak is coming from the rear of the oil filter housing, on a casing plug or something...
im looking into buying the housing used, because a new one is 430.
so in case i get it i will let you know how it goes..
But i would personaly try to fix this soon, letting the leak happen, is bad, since most likely youre loosing some oil pressure b/c of the laek..
victor.
You are a BMW driver when you become part of the &quot;Ultimate Driving Machine&quot;
Fraude an Fahren
BMW &gt; Bayerische Motorenwerke
www.clemsonfsae.com
Old 03-07-2005, 08:00 PM   #5 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
the plugs get jammed and turned ass backwards.. happened to me with my old engine when I was doing the swap.. I actually have a good working filter housing for sale on ebay :P there is real no way of fixing this issue from what my mechanic told me
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMESE%3AIT
jrhaile is offline   Reply With Quote
Old 03-07-2005, 08:00 PM   #6 (permalink)
tomctx's Avatar
Go to www.unofficialbmw.com. Click on E36, then forums. On page 2 (the last I looked) there is a thread by BMWlove on leak from oil filter housing. Good info.
Some of them can be fixed, some can't
Old 03-07-2005, 08:02 PM   #7 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
Vic I'll hook you up since you've been a big help to me in the past with some of my issues. I hope the one I have will work for you but not sure. it's from a 97 328i and was aparantly replaced at 45k miles by the previous owner of the engine. PM me.
Old 03-07-2005, 08:03 PM   #8 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
also forgot to mention, you'll need to get a new spaghetti (spelling) gasket for it if you do get a new/used one.
Old 03-07-2005, 08:09 PM   #9 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
and I spam some more...
Vic sorry man the one I have won't work it fits fine with a 325 engine but it messes with the power steering pump bracket somehow is what my mechanic told me. I do have another one that is from a 325i but it also has the same issue. My mechanic is looking in his "pile of shit" he calls because he things he has one from a 94 325i that was working fine. He's going to call me later tonight. I'll post in this topic if I have one. take it easy and good luck.
Old 03-08-2005, 08:21 AM   #10 (permalink)
Car: 1993 325i
[snapback]306025[/snapback]
Hey man, thnks,
My engine is the m50, i have a 1993 325i e36 all stock.
So if he can find the oil filter housing that is good let me know, Please!!!
THnaks
Victor
Fraude an Fahren
www.clemsonfsae.com
Old 03-08-2005, 08:24 AM   #11 (permalink)
Car: 1993 325i
o Yeah, Send me the part number form the oil housing, i will then check on the ETK to see if it fits,
Thanks
Fraude an Fahren
www.clemsonfsae.com
Old 03-08-2005, 10:47 AM   #12 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
we have one from a 93 that was left over after a swap he did when a guy over reved and bent some valves. I'm going to go look at it this friday to get part numbers and to make sure it works properly. I'll PM you.
Old 03-08-2005, 02:22 PM   #13 (permalink)
Car: 1993 325i
[snapback]306403[/snapback]
Thanks,
So you know, my car is an 93 with an m50 engine, so that one youre talking about fits..
Also, when you get the part, if the plug that leaks on the back is held in place by a metal clip, then it has a oring that can be purchased and replaced. If the plug is metal and doesnt have any metal wire or clip to hold in place, then the plug is press fit into it and an epoxy seals the part, either way, i can fix the parts even if they are leaking.
Anyway, i hope i can get one that works good..
Thnaks
Victor.
Fraude an Fahren
www.clemsonfsae.com
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
Oil Filter Housing Bolt morristhecoolcat 3-Series (E36) 6 04-25-2005 10:04 AM
Oil Filter Housing Rkhoubian 5-Series (E12,E28, E34, E39, E60) 3 04-12-2005 06:12 PM
How To Open The E39 Air Filter Housing wzhang91 5-Series (E12,E28, E34, E39, E60) 1 01-06-2005 03:17 PM
Oil Filter Housing Leak Quickman59 3-Series (E36) 4 10-25-2004 09:21 PM
