Oil leak - Is it engine's or tranny - BMW Forum - BimmerWerkz.com
Old 03-29-2007, 01:54 AM   #1 (permalink)
Criminal's Avatar
Car: 325i "95 , 318i "96
Criminal is an unknown quantity at this point
Hi,
I have a 318i ,96 with an M43 non-OBD engine. It's like M42. But there is an oil leak from a seal or a gasket between the engine and the gear. It's exactly at the joint between them. So Which oil is it? And is there any DIY for this?
Thanks
Criminal is offline   Reply With Quote
Old 03-29-2007, 10:03 AM   #2 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Is it the Rear crank seal?
Old 03-30-2007, 08:56 PM   #3 (permalink)
ex owner/admin
Furious's Avatar
yeah it could be the rear mainseal, there is no gasket on the bell housing to the engine so it would leak pretty obviously. the rear main is important to change because if not than your current clutch (if your manual) will start to fail and you will need to replace it.
if you can get a mechanic to verify that its the rear main seal and not something more extensive than id take the time to maybe consider changing the clutch and remachining the fly as it will be worth it since your basically going to be doing a "re-&-re" on the existing clutch, again get your trusted mechanic to verify and advise you on the proper course of action.
Old 04-02-2007, 03:05 AM   #4 (permalink)
Criminal's Avatar
Maybe it's the rear crank seal, but the car is Auto, and it's not leaking much oil, So is it important to change it.
Thanks
Old 04-02-2007, 04:17 PM   #5 (permalink)
fastshivy's Avatar
Car: 1999 540i
fastshivy is on a distinguished road
If you your transmission is not losing fluid(check the level) then it is probably a rear main seal. You really won't hurt anything as long as you keep the fluids topped off, it is just messy. If you are adding oil or transmission fluid every 200 miles or so, then yeah I would fix it.
fastshivy is offline   Reply With Quote
Old 04-04-2007, 12:41 AM   #6 (permalink)
Criminal's Avatar
Thanks to all of you. I figured that this is the engine oil leaking and it's not much, so I won't bother fixing it.
New Problem: Tranny Leak xx00xx 5-Series (E12,E28, E34, E39, E60) 9 11-05-2006 02:33 PM
oil leaking from a few places... yammahamma 3-Series (E21, E30) 31 11-02-2006 10:28 PM
Oil additives and the damage they do. Starmavin 3-Series (E21, E30) 2 05-18-2006 01:49 AM
oil leak in front of motor BImmerN2B 3-Series (E36) 15 05-04-2006 09:33 PM
Oil Leak From Bottom Of Engine??? BIG 730 1,6,7,8 - Series and Mini Cooper 3 12-19-2005 02:57 PM
