Originally posted by Furious@Apr 15 2005, 07:59 AM where is it leaking? how much and how do you know? is there a puddle where you park? or is oil just missing after a certain amout of time. is there any visual oil on the outter casing of the engine anywhere? (around the gasket areas) even check to see if the oil plug is loose [snapback]332767[/snapback] |
I think it is enigne oil , there is 5 to 10 drops of oil over the lot during the course of 3 to 4 hours. not sure how can i check from where it is leaking.THis is my first car that i ever owned. if don't mind can u tell me how can i check it ?
thanks a ton
SHeark
