Oil Leak!!!! - BMW Forum - BimmerWerkz.com
Old 12-16-2004, 11:30 AM   #1 (permalink)
fushuman is an unknown quantity at this point
Smile
So i woke this morning to go to school, and found a puddle of oil under the car ghead
It was about 6" diameter and i sure is engine oil 'cause when i started the car i saw some tiny drips coming from front mid-lower section of the block.
What could it be? i was thinking maybe its the oil pan gasket but i'm not sure?
can anyone me?
PS. and yeah its not my day, i'm failing Pre-calculus and my finals cross with my flight.
<img src='http://www.bmw-forums.com/forum/uploads/photo-7050.jpg' border='0' alt='user posted image' />
CONQUER THE WORLD WITH YOUR <span style='color:red'>HEART</span>!!!!!
CONQUER THE RACE WITH YOUR <span style='color:blue'>SOUL</span>!!!!
fushuman is offline   Reply With Quote
Old 12-16-2004, 11:59 AM   #2 (permalink)
DeefNDorf is an unknown quantity at this point
Send a message via AIM to DeefNDorf Send a message via MSN to DeefNDorf
Hmm..Sucks,,Keep an eye on that oil...
Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm...
DeefNDorf is offline   Reply With Quote
Old 12-16-2004, 12:26 PM   #3 (permalink)
ex owner/admin
Furious's Avatar
can you see any visible leak on the engine? maybe the profile gasket? or the oil pan gasket?
Old 12-16-2004, 01:21 PM   #4 (permalink)
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240 Send a message via MSN to uiuc240
could be front main seal. when that really lets go, get ready for a nice mess.
Eric
<img src='http://home.comcast.net/~eric_d_johnson/sig_pic.jpg' border='0' alt='user posted image' />
uiuc240 is offline   Reply With Quote
Old 12-16-2004, 03:56 PM   #5 (permalink)
RIBEMR26's Avatar
Did you just have your oil changed?....I know it sounds simple but did you check the plug? I have heard jiffy lube type horror stories about plugs being so loose they have almost fallen out....
Clear Corners and Sidemarkers
Old 12-16-2004, 04:16 PM   #6 (permalink)
What is the difference between the profile gasket and the oil pan gasket?
The leak is in front of the engine block almost in the middle and the mid-low part of it is kinda soaked in oil (no sludge).
Old 12-16-2004, 04:21 PM   #7 (permalink)
And also, what is the main seal?
I haven't done an oil change (i was thinking of swithcing tomorrow from regular oil to syntetic blend oil, but i guess thats out of the picture since the syntec oil would unplug more clogs an cause other leaks)
Old 12-16-2004, 04:22 PM   #8 (permalink)
and yes, i do change the oil every 3000 mi. just so you know
Old 12-16-2004, 04:30 PM   #9 (permalink)
Hmm..Good man..
Old 12-16-2004, 04:53 PM   #10 (permalink)
plz guys, what's the difference between profile gasket, oil pan gasket, and main seal? all these terms are driving me crazy
sorry... i'm just concerned about my precious baby
Old 12-16-2004, 05:24 PM   #11 (permalink)
no idea what the "profile gasket" is...as i'm still learning Bimmer terms.
oil pan gasket is found between the pan and the block.
main seal is the seal that the crankshaft sits in...it can be accessed by removing all the pulleys (including the big one attached to the crank) and then using a removal tool to get the seal out. not a fun job. and I haven't done this on a Bimmer, but the procedure is pretty much the same on all cars.
Eric
Old 12-16-2004, 05:32 PM   #12 (permalink)
And how hard is to change the oil pan gasket? to me, it seems like i would have to remove the steering rack Or could i work around it?
Old 12-16-2004, 05:36 PM   #13 (permalink)
Kevin325i's Avatar
Gotta drop the rack for that one.
Kevin (President TBEA)
Old 12-16-2004, 07:42 PM   #14 (permalink)
abemcclellan's Avatar
abemcclellan is an unknown quantity at this point
yep you gotta drop it to get it out.
abemcclellan is offline   Reply With Quote
Old 12-17-2004, 03:57 AM   #15 (permalink)
supark is an unknown quantity at this point
There's also a rear main seal as well that can only be accessed with the tranny out, but it sounds like your leak is in the front of the engine.
Just clean it real well with some no-residue degreaser and watch it to see exactly where it's leaking.
supark is offline   Reply With Quote
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
what engine oil to put in because i dont know if its syntec or normal? träumer 3-Series (E21, E30) 3 11-01-2005 02:40 PM
