Oil leak... - BMW Forum - BimmerWerkz.com
Old 09-06-2004, 01:03 AM   #1 (permalink)
Regnout
Guest
Posts: n/a
Hi All,
Just notice today that there is an oil leak underneath the engine toward the front of the car. Not sure exactly where its coming from. I degreased the "area" today in hoping to try and find the source.
This leak is recent 'cause I've been working on my car the past few weeks and didn't noticed it before. Here is what I did so far before the leak:
-Changed the valve cover gasket and plugs (Checked the gasket and no leaks anywhere)
-Changed the oil/filter myself for the first time (used Castrol 10W-40). Filter is clean on the outside and the drain plus is clean.
I'll try to get a pic of where the leak is and post it.
Any thoughts?
Old 09-06-2004, 08:32 AM   #2 (permalink)
thekid's Avatar
if you can get a good well lighted shot of under the car, it shouldn't be too hard to tell where it is coming from. Try and get a shot as far up as you can, the farther up and closer you can get will help out a lot. And also a pic from farther away, so we can tell where the closer pics are easier.
Old 09-06-2004, 12:30 PM   #3 (permalink)
Kevin325i's Avatar
I have a leak too
Kevin (President TBEA)
Old 09-07-2004, 10:11 AM   #4 (permalink)
Regnout
Guest
Posts: n/a
Well..I checked out under the engine last night and everything is dry...no leak visible. Will check again in a couple days and see. I have a feeling it will show up by then.
Old 09-07-2004, 11:13 AM   #5 (permalink)
dark_islight's Avatar
dark_islight is an unknown quantity at this point
Check the hose clamp on the bottom of the power steering reservoir. My 92 325i had a drip every once in while run down the tube. Its a bit of a pain to change the clamp if you don't pull the reservoir.
dark_islight is offline   Reply With Quote
Old 09-12-2004, 09:32 PM   #6 (permalink)
Regnout is an unknown quantity at this point
Well..I checked today and the oil leak is back. Here are 2 pics of it. Looks like it might be some kind of gasket?
The other side
Suggestions?
Regnout is offline   Reply With Quote
Old 09-12-2004, 09:36 PM   #7 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
pan gasket.. had the same leak.. fixed it.
jrhaile is offline   Reply With Quote
Old 09-12-2004, 09:48 PM   #8 (permalink)
jrhaile, did you fixed it yourself? If so, how difficult or PITA is it?
Old 09-12-2004, 10:06 PM   #9 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
hell no... had someone do it for me.. my mechanic did it... cost me about 150 in labor and 20 for the gasket. could also be your valve cover gasket which I did myself...
the car needed to be lifted up to get to it easily to do the pan.
Old 09-12-2004, 10:15 PM   #10 (permalink)
I have a leak in the head gasket for about 1 year now, the dealership gave me outragous quote to fix it ($1500-2000 canadian), I told them to fock off. Is the quote reseanable.
Old 09-12-2004, 10:42 PM   #11 (permalink)
I replaced the valve cover gasket a few weeks ago so can't be that. Gonna see if I can find any DIY on this. I just can't imagine bringing it to the dealer..its gonna cost me.
Old 09-12-2004, 10:44 PM   #12 (permalink)
Kevin325i's Avatar
It's not so bad really. Day long project. Just be thankful you can see your leak and aren't chasing it down like I have to.
Old 09-13-2004, 01:32 AM   #13 (permalink)
Deloriant's Avatar
Deloriant is an unknown quantity at this point
Send a message via AIM to Deloriant
Yeah, Kev loves his leaks, don't you Kev? <3
<img src='http://i116.photobucket.com/albums/o17/M4yorThis/119575444991686.jpg'>
Deloriant is offline   Reply With Quote
Old 09-13-2004, 07:08 AM   #14 (permalink)
RedBeemer95 is an unknown quantity at this point
I think .. he is.. I am also seeing some oil leakage .. but I need to get the damn coolant problem fixed.. and then look into the rest of the stuff.... (I am very new to this kind of stuff .. so, it may take a while to fix one by one) B) .
RedBeemer95 is offline   Reply With Quote
Old 09-13-2004, 03:50 PM   #15 (permalink)
Kevin325i's Avatar
The head gasket is next
Oil Leak htp.bmw 3-Series (E21, E30) 6 09-07-2005 12:15 AM
A Slight Leak mikester328 3-Series (E36) 1 01-06-2005 11:20 AM
