| First thing is to find the leak if there is any .Check the A/c compressor if it clicks on. Since you have the grills out, you might as well check the condenser for any traces of oil. That is usually the easiest place to find a leak. If you still cant find it, bring it to a shop for a/c test. Some shops will test the system and shoot it with a dye to check for leaks for $30.00. If it was the coolant leaking, the engine temp would be high and the coolant level low. Good Luck and let us know |
