Oil filter housing leak - BMW Forum - BimmerWerkz.com
Old 10-27-2012, 03:24 PM   #1 (permalink)
salp is on a distinguished road
I recently bought a 323is, which had an oil leak at the oil filter housing. I decided to have a small shop that specializing in bmw, mercedes do the repair. Well got car back and now its leaking more than it was before bringing to them for the repair. How hard is it to get a good seal on the gaskets? I'm not sure how this is going to turn out because when I got the car home I checked it and noticed it looked pretty wet. I called them up yesterday to find out about if the repair had a warranty and they said it was fine before it left there, but if it leaks they will make it right. I feel ripped off and im calling them monday. What is everyone elses take on this?
salp is offline   Reply With Quote
Old 10-27-2012, 05:48 PM   #2 (permalink)
Car: 94 325IS
ElTonyo69 is on a distinguished road
I would also be pissed. I recently changed my oil and I did notice that once I started to loosen the cap some oil did spill out. Could it be some of this overflow?
ElTonyo69 is offline   Reply With Quote
Old 10-28-2012, 12:32 AM   #3 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Confirm that the oil filter housing is new. The gaskets are included with the housing. Their are two gaskets.
If they say they will make it right, good. Take pictures of the leak before you go in though. You want proof that it is leaking should further action be required.
Click HERE to see my E36 Blog
Old 10-28-2012, 10:14 AM   #4 (permalink)
I should have stated that they changed the oil filter housing gasket, not the housing. Sorry, typo. But great idea on taking pictures, i will do that.
Old 10-29-2012, 12:46 AM   #5 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Well if they just changed the gasket itself their is the possibility the gasket wasnt installed correctly, or they cracked/damaged the housing in the process.
My mom has an 07 VW GTI and while getting an oil change they cracked the plastic oil filter housing and it started leaking. Their the same design as the E36 one.
Old 11-02-2012, 05:25 PM   #6 (permalink)
cjscopp's Avatar
Car: 2002 525i and 1995 325i
cjscopp is on a distinguished road
Chances are good that the leak is not from the gasket matign the housing to the block but from the o-rings that seal the galley plugs in the aluminum housing on the back side.
cjscopp is offline   Reply With Quote
Old 11-02-2012, 05:29 PM   #7 (permalink)
cjscopp's Avatar
Type Glorious oil leaks into the search function and you will find a great write up on this.
Oil filter housing and cap yammahamma 3-Series (E46, E90) 5 12-31-2009 11:04 AM
oil filter housing leak-HELP!! kylek325i 3-Series (E36) 1 05-28-2007 04:09 PM
Oil Filter Housing Rkhoubian 5-Series (E12,E28, E34, E39, E60) 3 04-12-2005 06:12 PM
Oil Leak By Filter Housing. Wtf?? victorgallas 3-Series (E36) 12 03-08-2005 02:22 PM
Oil Filter Housing Leak Quickman59 3-Series (E36) 4 10-25-2004 09:21 PM
