Oil Change, What Oil Is Recommended ? - BMW Forum - BimmerWerkz.com
Old 09-22-2004, 11:14 AM   #1 (permalink)
Q_BMW's Avatar
Q_BMW is an unknown quantity at this point
Send a message via AIM to Q_BMW Send a message via MSN to Q_BMW
Hey guys
its time to do my first oil change and have a few quick questions. I live around chicago, its kinda warm now(70 deg) and will be getting cold really soon.
the dealer said the only synthetic oil they have 5W-30 form mobil. would that be good through the winter till december or can someone recommend something better ?
Also do i need a jack to raise the car on stands before doing the oil change ? or i could squeeze underneath ?
thanks
Quasar
<span style='font-size:15pt;line-height:100%'><span style='color:red'>JUST SOLD:</span> <span style='color:blue'>01 BMW 330i with Sport &amp; M Package(5sp)</span></span>
<span style='font-size:14pt;line-height:100%'><span style='color:blue'>Past:</span> <span style='color:red'>1996 BMW 328i</span></span>
<span style='font-size:14pt;line-height:100%'><a href='http://www.ofoto.com/BrowsePhotos.jsp?&collid=10038932107&page=1&sort_o rder=0' target='_blank'>PICTURES!!</a></span>
Q_BMW is offline   Reply With Quote
Old 09-22-2004, 11:16 AM   #2 (permalink)
bdi_fc is an unknown quantity at this point
Originally posted by Q_BMW@Sep 22 2004, 10:14 AM
Hey guys
thanks
Quasar
[snapback]196724[/snapback]
0-40 Synthetic
bdi_fc is offline   Reply With Quote
Old 09-22-2004, 12:01 PM   #3 (permalink)
ex owner/admin
Furious's Avatar
im not sure how cold it gets in chi-town, but here in canada 5w30 is ok however only during very cold winters, otherwise a nice 10w30 would be ok.
Old 09-22-2004, 04:17 PM   #4 (permalink)
Q_BMW's Avatar
0-40 ? that wont be too thick for the midwest winter ?
Old 09-22-2004, 04:28 PM   #5 (permalink)
BMDub325is is an unknown quantity at this point
I'd say 10w 30 for chi town. I live in Cincinnati (same temp range) and that will be what i run this winter. My manual says 15w 30 for our temps though. I am running 10w 30 right now but i wish i would have went thicker for the hot weather. O well. Always run synthetics though. Blend is cheaper.
As far as squeezing under the car if you are super skinny and your oil pan is super thin you can do it. If you do jack it up you will want it level so it gets all the old oil out. Good luck (dont forget to change filter too)
92' 626 ES
88' Mazda Truck
92' VW passaat (sold)
93' BMW 325is
86' BMW 318is
<img src='http://www.geocities.com/bmdub325is/images/current/signaturefinal2.JPG' border='0' alt='user posted image' />
<a href='http://www.geocities.com/bmdub325is' target='_blank'>***MY E36 BUILDUP PAGE***</a>
BMDub325is is offline   Reply With Quote
Old 09-22-2004, 04:31 PM   #6 (permalink)
Q_BMW's Avatar
hey thanks
also so 10w 30 will be fine if i switch it now rite ? is monil the company to go with ?
anyone have good experiences with redline ?
also quick question, i would jack up the car belowe the passenger door side rite ? below the skirt ?
thanks guys
Q
Old 09-22-2004, 04:57 PM   #7 (permalink)
theogill is an unknown quantity at this point
Send a message via MSN to theogill
I live in Boston, jsut had an oil change done by the dealer. They put 5w30 BMW synthetic for 80 bucks. Mine's a 98 328i, manual, 52K.
Cheers
98 328i, black/black, manual, canadian sport pkg, ECIS intake, koni sport adj's, dinan springs, oe/oem clears.
Considering: tms shark,M 17&quot; wheels, larger sway bars.
theogill is offline   Reply With Quote
Old 09-22-2004, 06:04 PM   #8 (permalink)
[snapback]196903[/snapback]
First number is cold performance (lower the better).
Second number is hot-weather performance (higher the better).
0-40 is the end-all-be-all oil.
http://forum.e46fanatics.com/showthread.ph...5&highlight=oil
Old 09-22-2004, 10:22 PM   #9 (permalink)
Q_BMW's Avatar
cheers , thanks guyrs
Old 09-23-2004, 12:20 AM   #10 (permalink)
ex owner/admin
Furious's Avatar
i find 0-40 a hard oil to find sometimes, maybe its me, but i agree 0-40 is best choice, my suggestion for 10w30 lies in the accesability of it, and also because it works great in milder climates (mild is a loose term, i say mild because i dont think it reaches minus 40+ like it does here )
Old 09-23-2004, 08:57 AM   #11 (permalink)
Q_BMW's Avatar
cool, will look for 0-40....also anyone have any experience / opinions on the K&N oil filters ?? good ...bad ???
thanks
Q
Old 09-23-2004, 04:36 PM   #12 (permalink)
thanks
Q
[snapback]197454[/snapback]
I found 2 boxes (12 quarts) of Mobil 1 0-40 at Pep Boys. While I was buying it, the manager mentioned the fact that she ordered it only because it was on sale, which means I probably will have to go to my local german parts shop to get 0-40 or order some online.
Definitely go for 0-40 Synthetic.
K&N is always good.
what transmission and differential oil should i use? träumer 3-Series (E21, E30) 6 10-10-2005 01:42 PM
A Year Passed And I'm Still Not Changing The Oil AIO 3-Series (E46, E90) 26 10-10-2005 08:43 AM
timing belt change and mechanics in miami träumer 3-Series (E21, E30) 6 10-03-2005 03:44 PM
