Oil Change Question Again - BMW Forum - BimmerWerkz.com
Old 09-28-2004, 10:48 AM   #1 (permalink)
Q_BMW's Avatar
Q_BMW is an unknown quantity at this point
Send a message via AIM to Q_BMW Send a message via MSN to Q_BMW
hey guys
after much research on other forums i have decided to go with mobil 1 0W-40
however a buddy just told me that since my car has almost 110K miles on it I should go with atleast 5W-40 or 10-40 since the bearings and all are probably worn out and 0 viscosity is too thin for high mileage cars.
any suggestions ? I drive my car real hard when i can on the streets, but i am aroudn chicago and winter will kick in a month,
Q
<span style='font-size:15pt;line-height:100%'><span style='color:red'>JUST SOLD:</span> <span style='color:blue'>01 BMW 330i with Sport &amp; M Package(5sp)</span></span>
<span style='font-size:14pt;line-height:100%'><span style='color:blue'>Past:</span> <span style='color:red'>1996 BMW 328i</span></span>
<span style='font-size:14pt;line-height:100%'><a href='http://www.ofoto.com/BrowsePhotos.jsp?&collid=10038932107&page=1&sort_o rder=0' target='_blank'>PICTURES!!</a></span>
Q_BMW is offline   Reply With Quote
Old 09-28-2004, 10:53 AM   #2 (permalink)
kjlbryan is an unknown quantity at this point
ye...
I agree w/ your friend, I wouldnt use such a thin oil (0W - 40) for a high mileage car... i'd use anything 10W and above...
hope this is useful
kjlbryan is offline   Reply With Quote
Old 09-28-2004, 05:10 PM   #3 (permalink)
Q_BMW's Avatar
hey
cool thanks man, gonna get 10W-40 if i find some otherwise the bmw 5-30
Q
Old 09-28-2004, 06:28 PM   #4 (permalink)
Kevin325i's Avatar
I use 0-40 with 113k, no issues with burning oil.
Kevin (President TBEA)
Old 09-28-2004, 09:34 PM   #5 (permalink)
bdi_fc is an unknown quantity at this point
0-40 is NOT thin.
And countless BMW members have first hand experience switching to Synthetic (including myself) with various mileage readings with no leaks.
bdi_fc is offline   Reply With Quote
Old 09-28-2004, 09:41 PM   #6 (permalink)
69th Gear Member
BeachBunny's Avatar
Car: 1996 328IS
BeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond repute
Are you changing your own oil? Do you know what I found out?! BMW makes you get a special tool goddamnit (I forget what it's called) to get off the oil filter cover thingie! I didn't have one and now I've got little scratches from the wrench!
It's been a long day.. did I make sense? used
BeachBunny is offline   Reply With Quote
Old 09-28-2004, 11:56 PM   #7 (permalink)
Q_BMW's Avatar
hey
yes i was planning on doing it myself tomorrow. will ask the dealer. how much does that tool cost ?
thanks man
Q
Old 09-29-2004, 12:01 AM   #8 (permalink)
69th Gear Member
BeachBunny's Avatar
Car: 1996 328IS
I think it's like 5 bucks?
Old 09-29-2004, 12:04 AM   #9 (permalink)
Q_BMW's Avatar
ok mite get it then, how bad were the scratches ? wonder if i care about them that much.
so 0-40 should be good for high mileage rite ? kevin said no problem with his......how often do u guys switch synthetic ....7K ?
thanks
Q
Old 09-29-2004, 12:12 AM   #10 (permalink)
69th Gear Member
BeachBunny's Avatar
Car: 1996 328IS
Well, it's under the hood so I didn't cry about it that night... and I heard it's cheap to replace... still, if you plan to keep changing your oil, I'd buy the thing at the dealer... it's worth it.
Old 09-29-2004, 09:41 AM   #11 (permalink)
Henri is an unknown quantity at this point
For those who have a black plastic oil filter housing cap (it's less usual than the silver metal cap), you will certainly need a special tool made by CarTool especially for BMW. I bought this for approx. 20$ (Cdn , so approx. 14$ USD). Without this, it will be such a pain to change your oil filter. This tool is available in BMW dealerships.
Have fun
Henri
Henri is offline   Reply With Quote
Old 09-29-2004, 06:19 PM   #12 (permalink)
RIBEMR26's Avatar
I went through the same thing...chewing up that plastic cover....Use your channel lock pliers on the plastic "bolt" on top...then stick a quality screw driver through the pliers so you can turn it the whole housing...this is the only efficient way to do it w/out ripping apart the top of the cap, or buying the special tool...
Clear Corners and Sidemarkers
Old 09-29-2004, 09:36 PM   #13 (permalink)
Q_BMW's Avatar
its all good, did mine today. a buddy has tool so it worked out fine
Q
Quik oil change question wulley1 3-Series (E36) 11 08-19-2004 09:49 AM
New BMW owner with oil change question... kevandju 3-Series (E36) 10 07-16-2004 09:39 PM
Oil Change Question Frozenwave 1,6,7,8 - Series and Mini Cooper 2 03-10-2004 10:49 PM
Question about change the plastic impeller alienbust 3-Series (E36) 6 01-03-2004 01:08 PM
