oil change help please - BMW Forum - BimmerWerkz.com
Old 03-29-2006, 12:22 AM   #1 (permalink)
moe_j is an unknown quantity at this point
hi guys.
its just a silly question but im confuse here. its for my 325i 94 with 135k miles on it. should i put 15-40 syntatic or 15-40 regular engine oil. is it good to put syntatic with these kind of miles?
and one more question does manuel 325i has some kind of transmision oil if so where does it goes. and wat type it should be?
used:
thanks
moe_j is offline   Reply With Quote
Old 03-29-2006, 03:06 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
http://www.bimmerwerkz.com/forum/3-s...5is-45216.html
Old 03-31-2006, 01:41 AM   #3 (permalink)
mtechnology is on a distinguished road
i would stick to mineral
mtechnology is offline   Reply With Quote
Old 03-31-2006, 02:24 AM   #4 (permalink)
vwk
vwk is an unknown quantity at this point
And I would advise you syntethic
Tranny fluid doesn't need to be replaced, it's free of service
Euro E36 M3 3.2 Rebuild Project
27 years
vwk is offline   Reply With Quote
Old 04-01-2006, 12:02 AM   #5 (permalink)
doesnt hurt to check auto tranny fluid levels...
i even changed the filter, fluid and used new gaskets
a hose with a tiny slow drip or bad gasket could get the levels low over years
Old 04-01-2006, 01:03 AM   #6 (permalink)
ex owner/admin
Furious's Avatar
to check or change your tranny fluid the process is a bit like your diff. there are two bolts, one on the bottom for draining, and one on the side for filling and checking. what you do is drain your old fluid, than replace the plug. than using a pump system or if you find a long enough hose (you need to use gravity to get the fluid in) you need to fill until the fluid just starts to spill out (ever so slightly).... to check the level you need to open your side plug and if a bit drips out than your safe, if not stick your finger in , if you can feel the level is just at the edge than it will be ok, if its a bit lower than you can top it off.
auto tranny fluid is suppose to be lifetime (although i dont buy that) manual tranny fluid i change every season, just because of the way i drive , its a bit excessive but it cant hurt
Old 04-01-2006, 12:12 PM   #7 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
My auto tranny looks like it has plastic drain plugs that would deform permanently if you tried to remove them to change the fluid. Solutions?
Lindsay fan club member.
oil leaking from a few places... yammahamma 3-Series (E21, E30) 31 11-02-2006 10:28 PM
Easy oil change question Ocean02 3-Series (E46, E90) 5 03-14-2006 12:29 PM
17 months passed without an oil change!!! AIO 3-Series (E46, E90) 36 01-26-2006 01:32 PM
oil change 318itx 3-Series (E36) 8 01-23-2006 12:28 PM
oil change! 318itx 3-Series (E36) 26 01-15-2006 05:59 PM
