ok wellz i was doing my oil change today and i was done taking off the oil and change the filter and everything... when i was putting back my oil drain plug the screw for the oil plug snapped in half !!! ghead now then i drilled that half peice that was stuck there and that thing went inside!!! holy crap!!!
my question now is will there be a problem if i just leave that peice inside the oil pan and buy a new drain plug and close it... would that small screw mess up my car?? need help!
Ummm....yes. I don't think it would be wise to have a large chunk of alluminum sitting in your oil pan, while you attempt to run your engine. At this point, I would recomend dropping your oil pan, and retrieving that what's left of your drain plug before you decide to go for a spin.
If not you could seriously dammage your engine if shavings of what's left of your drain plug actually reached the internals of your engine. What might cost you a couple hundred bucks of removing your oil pan, could cost you an engine, if your unlucky enough and don't.
This may not be so bad to fix. If I were in this situation, I would purchase a magnetized "part retriever/wand" (they're long and flexible and are designed to retrieve screws et. al. which fall into your engine bay -- sorry, don't know the exact name), drain the oil, and try to retrieve the remnant of the plug. As long as there aren't excess shavings hanging around, I would imagine this would do the trick!
Very likely that will be a problem. Drop the oilpan, clean it well, and put it back with a new gasket. Decently easy to do. A friend of mine did it on his E30 6-cyl and he had NO previous mechanical experience.
Originally posted by PR325is@May 15 2005, 01:47 PM ok wellz i was doing my oil change today and i was done taking off the oil and change the filter and everything... when i was putting back my oil drain plug the screw for the oil plug snapped in half !!! ghead now then i drilled that half peice that was stuck there and that thing went inside!!! holy crap!!!
[snapback]344745[/snapback]
drain oil, save it or not, your choice, then remove the oil pan (it's no big deal) and remove the particulate. Problem solved.
Addicted to Speed Since 1997 Founding member of the GreenDragon Poo Flingers Club
