Oil in a 328i - BMW Forum - BimmerWerkz.com
Old 07-10-2004, 01:36 PM   #1 (permalink)
iantosca's Avatar
iantosca is an unknown quantity at this point
Send a message via AIM to iantosca
My car is inching towards the 100,000 mile marker and is in need of an oil change. What oil do you recommend i use in a '98 328i with that kind of mileage?
Thanks in advance.
98' BMW 328i - Jet Black, Black Leather, Alpine CDA-9831 HU
<span style='color:red'>For Sale:</span> Sony CDX-F5000 Xplod w/ Wiring Harness, iBook G3 900 Mhz 640 MB SDRAM w/ Original Box and Software + OS X Panther + Microsoft Office
(PM on any offers, Going on E-Bay soon ...)
iantosca is offline   Reply With Quote
Old 07-10-2004, 03:10 PM   #2 (permalink)
WOT in Reverse
jllphan's Avatar
BMW North America recently sent a memo to authorized BMW service centers recomending a 20W50 for year around oil changes. IMO castrol would be my choice in this weight.
My car's engine is rapidly approaching the 100K mark, and was iffy about changing to synthetic. My desire to do so was predicated on the fact that it has been said that synthetic contains superior lubrication and protection against viscosity break down. It also supposedly extends the life of the VANOS unit, which can be very expensive to replace if failed.
I decided to switch to RedLine 10w40. This lighter weight sythetic is said to offer superior lubrication over a petroleum based 20W50. It may be psychological, but I swear my car idles smoother and has better low end acceleration. It is pricey at $8 a quart, but the recomended change intervals are 13-15K miles compared to 3K for a standard oil. I plan on changing the filter every 5K and the oil every 10K.
Old 07-10-2004, 03:42 PM   #3 (permalink)
iantosca's Avatar
Thanks again.
Old 07-10-2004, 04:14 PM   #4 (permalink)
Q_BMW's Avatar
Q_BMW is an unknown quantity at this point
Send a message via AIM to Q_BMW Send a message via MSN to Q_BMW
hey
i have 106K miles and only get synthetic oil changes. I thought it was recommened to change synthetic every 7K miles? is that correct? so it would be good to still change the filter every 5K?
thanks
Q
<span style='font-size:15pt;line-height:100%'><span style='color:red'>JUST SOLD:</span> <span style='color:blue'>01 BMW 330i with Sport &amp; M Package(5sp)</span></span>
<span style='font-size:14pt;line-height:100%'><span style='color:blue'>Past:</span> <span style='color:red'>1996 BMW 328i</span></span>
<span style='font-size:14pt;line-height:100%'><a href='http://www.ofoto.com/BrowsePhotos.jsp?&collid=10038932107&page=1&sort_o rder=0' target='_blank'>PICTURES!!</a></span>
Q_BMW is offline   Reply With Quote
Old 07-10-2004, 04:23 PM   #5 (permalink)
WOT in Reverse
jllphan's Avatar
Q, stick with your routine. Your all good.
Red Line is different from Mobil 1 and others, and has a longer change interval. And while they say the oil is rated at 17K intervals, it doesn't take care of any potential crap that can get in there. Changing the filter more often, will aleviate that. Plus, I'm a little anal....
Old 07-10-2004, 05:08 PM   #6 (permalink)
Q_BMW's Avatar
hey
thanks jilphan, it also depends on how one drives right ? high revin sporty drivin will suck the oil out sooner then scheduled. is redline better then mobil apart from the fact that it last longer?
Q
Old 07-10-2004, 06:56 PM   #7 (permalink)
WOT in Reverse
jllphan's Avatar
opinions vary, but after much research, I am now convinced that Red Line is the best consumer engine oil available. Take a look...{HERE}
And it really doesn't matter how you drive (unless of course you track your car). Standard recomended change intervals are 3K for petroleum based oil and 7K for synthetics. Like I said, Red Line is a little different.
Old 07-10-2004, 06:59 PM   #8 (permalink)
iantosca's Avatar
I hard that if i was to change to synthetic right now that my engine would leak. Also, how much oil does a 328i engine hold?
Old 07-10-2004, 08:24 PM   #9 (permalink)
Kevin325i's Avatar
To each his own. Jllphan likes Redline, I like Mobil 1, others like Amsoil. Really they all say you can go up to 15k miles on their synthetic oil. Basically I feel that the 8 bucks a quart for Redline is really just buying the name brand. ALso I'm kinda lazy and I jump into things, I can find Mobil 1 relatively easy but I have to drive a long way to get Redline.
Bottom line. Find the company with the full synthetic in the weight you want. Or the one that has the fanciest sounding website, in any case synthetic gives you a wider temperature range then conventional oil and has better flowing properties, blah blah read some websites till you get sick of their info, then buy the stuff from whatever site you're on.
Kevin
P.S. Anyone know a good online distributor for Redline, I think I might get some ATF from them. Right now I'm rollin' the full synthetic B&M Trick Shift, I don't know if I'll keep it.
Kevin (President TBEA)
Old 07-11-2004, 12:28 AM   #10 (permalink)
EuroBeem's Avatar
EuroBeem is an unknown quantity at this point
my 97 328i held 6.9 liters...thats what the bmw dealership said to....I live in jersey also and the guys at BMW told me to run 5w-30 Synthetic oil. I used to run regular oil in it, but finally decided to change the filter, drain the oil, and run synthetic !
Works great.
EuroBeem is offline   Reply With Quote
Old 07-11-2004, 04:32 PM   #11 (permalink)
iantosca's Avatar
Thanks eurobeem and everyone for their input.
Old 07-11-2004, 06:04 PM   #12 (permalink)
roguesniper1's Avatar
Car: 97 528i and 94 325i
roguesniper1 is an unknown quantity at this point
Send a message via AIM to roguesniper1
I run mineral oil , 20W-50 Castrol GTX. Yus, I am a cheap bitch, but I still change my oil at every 3000 miles religiously.
PS: A month ago on sale, I picked up 10 Cases of Castrol for $14.51 each. Talk bout UBER deal
roguesniper1 is offline   Reply With Quote
Decision: 325i Vs 328i ynotony 3-Series (E36) 10 05-26-2005 09:16 AM
