| do you know if it is a pre or post 1995 alarm brain? if you could send pictures of your actual unit, it would help. If it has a permanently attached antenna, then it is a post 1995, if the antenna is removable via a plug in type deal, then it is pre 1995. The post 95 uses the round 2 button remotes, the pre 1995 one uses the 3 button rectangle remotes. more questions email me <318noire@gmail.com> |
