odometer not working - BMW Forum - BimmerWerkz.com
Old 08-04-2004, 04:58 PM   #1 (permalink)
funtoos's Avatar
funtoos is an unknown quantity at this point
Send a message via AIM to funtoos
hey guyz,
this is not a bmw question.. but thought i might ask..i m sure somebody must have ran into this situation...
i have a 95 altima and all of sudden the odometer stopped working... everything else works (meaning the rpms, speedometer, all the guages).. but the miles do not seem to move
do you what this can be? where can i start looking?
thanx
'04 330Ci
'00 Kawasaki ZX9-R
Now looking for an M3
funtoos is offline   Reply With Quote
Old 08-04-2004, 05:02 PM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Wish mine would do that..... It probably failed due to either a problem with the reels inside.. or with some type of transfer between that and the tires... try looking on the back of your gauges....
1997 E36 M3 1990 E30 325i
Old 08-04-2004, 05:07 PM   #3 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
kestrel325is is an unknown quantity at this point
the back of the Altima's gauge cluster (the odometer in particular) is driven by a small motor with a worm gear on it. Over time, the worm gear becomes separated from the driveshaft of the electric motor, and doesn't register the odometer.
Take the gauge cluster out, remove the motor, and push the worm gear back on it. A little dab of superglue will fix the problem.
I had this same thing happen to a friend's 240sx.
There are all kinds of nissan forums available, but the best is
Fresh Alloy
Hope this helps!
kestrel325is is offline   Reply With Quote
Old 08-04-2004, 07:20 PM   #4 (permalink)
funtoos's Avatar
kestrel,
does this mean i would have to remove the dash to get to the guage cluster? where is this located exactly... and how hard would this be? u have any dyi on removing the dash to get to it? or am i completely lost?
thanx
'04 330Ci
'00 Kawasaki ZX9-R
Old 08-04-2004, 07:51 PM   #5 (permalink)
Originally posted by funtoos@Aug 4 2004, 08:00 PM
kestrel,
thanx
you need to remove the dash surround, as the cluster is held in by 4 screws behind it.
I don't have a walkthrough handy, but try the freshalloy forum. they might have a link that you can use...
All in all, the job's not very hard.
Old 08-04-2004, 08:04 PM   #6 (permalink)
funtoos's Avatar
thanx
'04 330Ci
'00 Kawasaki ZX9-R
Spedometer & Odometer Intermittently quit working osestrada 3-Series (E36) 2 10-13-2005 12:17 PM
Odometer Stopped Working jgentile1 3-Series (E21, E30) 2 03-05-2005 02:13 PM
Odometer On Cluster Guage Not Working SemiPerfect 3-Series (E36) 4 10-13-2004 01:28 PM
Odometer Light stopped working kjlbryan 3-Series (E36) 3 05-28-2004 06:12 PM
