Occasional Vibrating Steering Wheel - BMW Forum - BimmerWerkz.com
Old 06-28-2004, 09:44 AM   #1 (permalink)
gabeshmabe is an unknown quantity at this point
About once a week during my normal commute in my 99 323iS, after about 1/2 hour, my steering wheel will start to vibrate as if my wheels were out of balance. Sometimes it goes away after 5 minutes, sometimes it sticks around for 20 minutes. Speed doesn't seem to be a factor as I've felt it at 5mph and 75mph. Sometimes the vibration isn't too bad, sometimes it feels like a rhino is dancing on my hood. I had a shop check out the steering and suspension and didn't see a problem. They balanced the tires and the problem went away for about a month, then it came back. Has anyone out there experienced anything like this?
gabeshmabe is offline   Reply With Quote
Old 06-28-2004, 12:08 PM   #2 (permalink)
BlantonG13's Avatar
BlantonG13 is an unknown quantity at this point
Send a message via AIM to BlantonG13
get the wheel bearings checked out...that could definitely cause vibration in steering. Do you have aftermarket wheels?
1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12" Alpine Type-R, sealed box
Infinity Kappa 4" 2-way speakers(rear)
Infinity Kappa 5.25" component speakers(front)
Debaffled airbox, K&N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
BlantonG13 is offline   Reply With Quote
Old 06-28-2004, 12:22 PM   #3 (permalink)
/Banned
okczy21 is an unknown quantity at this point
i had the same problem and i took it to my bmw shop and the simply put the proper amount of air in each tire and it fixed the problem u need to check ur tires probably weekly cause im pretty sure thats the problem or u just need new tires all together
okczy21 is offline   Reply With Quote
Old 06-28-2004, 12:53 PM   #4 (permalink)
The wheel bearings sound like a likely suspect. I've been hearing some noises coming from the wheel when I parallel park that I thought were a seperate problem, but it seems like both problems could be caused by the wheel bearings. I'll give them a good hard lookover. Thanks!!
Old 06-28-2004, 01:22 PM   #5 (permalink)
Parkerton is an unknown quantity at this point
Gabe,
we just bought a 98 323is and my wife said she felt it, but I haven't since we've had it (just one month). Keep us posted on what you do...I'll do the same.
Thanks.
Parkerton is offline   Reply With Quote
Old 07-06-2004, 01:19 PM   #6 (permalink)
Minor Update: I checked out my wheel bearings and they are fine. I figured I'd shoot for the easy fixes and got my wheels balanced again and also got an alignment. No luck. I'll be taking my car to a good shop within the next couple of weeks. I'll let you know what the verdict is.
Old 07-06-2004, 01:22 PM   #7 (permalink)
Q_BMW's Avatar
Q_BMW is an unknown quantity at this point
Send a message via AIM to Q_BMW Send a message via MSN to Q_BMW
hey gabe
sorry to break this out but i had the same problem, balancing and alignment did not work. The I got it checked and somehow all my rims are slightly bent which cause vibrations ocasionally at no set speed range.
check those rims out...i have no clue how mine bent
Q
<span style='font-size:15pt;line-height:100%'><span style='color:red'>JUST SOLD:</span> <span style='color:blue'>01 BMW 330i with Sport &amp; M Package(5sp)</span></span>
<span style='font-size:14pt;line-height:100%'><span style='color:blue'>Past:</span> <span style='color:red'>1996 BMW 328i</span></span>
<span style='font-size:14pt;line-height:100%'><a href='http://www.ofoto.com/BrowsePhotos.jsp?&collid=10038932107&page=1&sort_o rder=0' target='_blank'>PICTURES!!</a></span>
Q_BMW is offline   Reply With Quote
Old 07-13-2004, 09:12 AM   #8 (permalink)
Thanks for all the help and ideas! After taking my car to 3 different garages, after having my front struts, front upper mounts, and tie rods replaced because they were damaged/warn out from the vibration, and after warping a new rotor in 3 days, the problem ended up being a sticking caliper. My car's all better now. My credit card isn't. Who would've thunk it cost a lot of money to fix a beamer
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
Steering Wheel Upgrade Options gmal 5-Series (E12,E28, E34, E39, E60) 0 10-28-2004 08:25 AM
Steering Wheel / Steering Feeling {|nf3rn0} 3-Series (E36) 0 10-21-2004 03:23 AM
Triangle 3 spoke Sport Steering wheel woobiee Classifieds Sell & Buy 11 10-03-2003 03:08 PM
