Obd1 Fault Codes, Help! - BMW Forum - BimmerWerkz.com
Old 07-29-2005, 08:29 PM   #1 (permalink)
toast_mcmann is an unknown quantity at this point
I have a 95 325is, my check engine light is on and I just failed my emissions test. So I decided I would use the peddle stomp trick to find out my fault codes. I followed the link on the pelican parts web site, and to my surprise no fault codes were sent. So I popped my hood and sure enough my car is indeed OBD1 certified, and manufactured in 04/95. So why won’t my car throw codes? I’m turning the key into the on position making sure the engine is off and stomping the gas 5 times in five seconds just like the article says. Please someone tell me why I can’t get my fault codes.
toast_mcmann is offline   Reply With Quote
Old 07-29-2005, 11:29 PM   #2 (permalink)
Please tell me someone here knows what I'm talking about. Any suggestions would be much appreciated.
Old 07-30-2005, 10:43 AM   #3 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Are you making sure that you press the gas pedal all the way down and all the way up (even let your foot off the pedal)?
Turkey Fleet Bond Holder
Old 07-30-2005, 04:01 PM   #4 (permalink)
NESS is an unknown quantity at this point
There are some threads on this already that will help you try to search for them.
NESS is offline   Reply With Quote
Old 07-30-2005, 04:31 PM   #5 (permalink)
I've tryed about every type of stomping style that could possibly exist. At this point I'm thinking that something could be broken.
Old 07-31-2005, 01:36 PM   #6 (permalink)
I have the same exact model you have. Ive tried it a couple times and never got it to work. My CEL and Check light both came on right after I bought my car, but for the past month they have not come on once. Yet I still have a rough idle sometimes, Im getting 16mpg, and the car feels like it should accelerate better.
Old 07-31-2005, 05:51 PM   #7 (permalink)
You should be getting way better mileage than that! I get 24 around the city and 29-30 on the highway. The first thing I would do if I were you, is replace my oxygen sensor. A bad oxygen sensor can be responsible for a rough idle, poor mileage, and also will turn on your check engine light.
Old 07-31-2005, 06:00 PM   #8 (permalink)
Yea thats what I think it is but my CEL light hasnt been on in a month. It stopped coming on once I got my rotors shaved and when I was putting them back on the wire for the Anti-Lock brake sensor? was already ripped and it completely broke, so now I have that red circle always showing up but no CEL light.
Can they still pull the codes if the CEL light isnt on? Im sure they could check if the 02 sensor is bad just by looking at it, but I would like to make sure its not something else to.
Old 07-31-2005, 08:32 PM   #9 (permalink)
luckly thats not your abs sensor, it senses the thickness of your brake pad. I'm not sure how having it ripped off would affect your check engine light, since it is what turns on the red circle you speak of, telling you that the brakes need changed (in your case a new sensor).
Old 08-01-2005, 01:11 AM   #10 (permalink)
Check engine light just came on again tonight when I let my brother drive so Im taking it to get looked at tomorrow.
Old 08-01-2005, 10:08 PM   #11 (permalink)
bimmerguy82's Avatar
Car: 2004 ZHP 6SPD
[snapback]366130[/snapback]
yeah, i have a 92' 325i, and i just pulled a code on mine cause the check engine light came on because the stupid chip i got does not like my DME. but, it takes precise timing and repeated tries to get it right. make sure you go all the way to the floor until you hit the button behind the gas pedal. (5x) and you can find what the code means if you have a bentley manual.
BMWcrazy
___________
-Joshua
BMWCCA member#407674
Fault Codes liltrig99 3-Series (E36) 1 08-19-2005 07:15 AM
M3 Fault Codes? beemernubee M-Series (M1, M3, M5, M6) 2 04-06-2005 12:49 AM
1998 M3 Fault Codes beemernubee 3-Series (E36) 1 03-27-2005 01:26 PM
M40 Fault Codes. SBSD 3-Series (E36) 3 02-13-2005 01:51 PM
