OBC different models -- set to English - BMW Forum - BimmerWerkz.com
post #1 of 7 (permalink) Old 01-14-2012, 09:53 AM Thread Starter
George :-)'s Avatar
George :-) is on a distinguished road
Hello all!
I have searched and searched to no avail for information on setting the "check control/ambient temperature/clock" version of the MIB, commonly referred to in the Bentley as the OBC.
The Bentley manual lists four different models of computer for the e36 cars and the one I have is referred to as the "check control/ambient temperature/clock".
The manual is of no further help with these computers.
I need specific instructions for setting to English language operation and using the "check control/ambient temperature/clock" version which is currently displaying German language messages.
I have tried the sequence for the OBC version but it does not work. (not as many buttons)
Please help!
Thanks!
George :-)
George :-) is offline
post #2 of 7 (permalink) Old 01-14-2012, 10:38 AM Thread Starter
George :-)'s Avatar
here's the one that I have. (11 buttons)
post #3 of 7 (permalink) Old 01-14-2012, 12:28 PM
Captain... Savvy ?
Jack Dabsy's Avatar
Quoted: 1 Post(s)
Did you try this?
To determine if your OBC is eligible .. press 1000 and 10 together.
you should see TEST NO . -- or something like that.
Now, some of the functions are locked out -- I do NOT recommend messing with them and you do so at your own risk -- that said ...
To unlock all functions .. press 1000 and 10 and at the TEST prompt enter 19 using the keys .. press SET/RES .. you should see LOCK:ON or something similar ... press the DATE key .. and add the two numbers (day and month) together...
Now enter the number you just calculated and press SET/RES. TADA .. you have unlocked the secret functions ...
To lock them back up .. press 1000 and 10 then enter 19, SET/RES now press SET/RES again .. it should show .. LOCK:ON again
In general when I show a test enter it by pressing 1000 and 10 together then enter the number of the test with the numeric keys and press SET/RES to actually execute the test ...
Test numbers for E36 OBC
Test no. Description
1 Display Test .. all LCDs and LEDs activate
2 Current Consumption in l/100km
3 Current Consumption in l/hour
4 Average Consumption (used to calc. Range)
5 Current Range
6 Not used ..
7 Average Fuel in Tank (l)
8 Current Speed (km/h)
9 System Voltage at terminal R
10 Country/Language
11 Units/ AM.PM
12 Average Speed (km/h) for calc. ETA
13 ETA
14 Date of software/mask of OBC
15 Production Diagnosis (??)
16 Production Diagnosis (??)
17 Display Vehicle Specific Data
18 Alarm Changeover (continuous v. intermittent)
19 LOCK/UNLOCK all functions
20 Correction Factor for OBC Fuel Consumption (SEE BELOW!)
21 Reset all defect codes, date and time ... activate by pressing SET/RES
Eso es todo!
Jack Dabsy is offline
post #4 of 7 (permalink) Old 01-15-2012, 12:23 PM Thread Starter
George :-)'s Avatar
Not getting those responses but I'll try it again but part of the problem is it's in GERMAN, which I don't sprechen, but I'll take the laptop with google translate out to the car and try again.
Are there no directions from BMW for my specific type of 11 button OBC?
post #5 of 7 (permalink) Old 01-15-2012, 02:33 PM Thread Starter
George :-)'s Avatar
Okay, so I press 1000 and 10 simultaneously and it reads "Funktion: -- --" . I then enter 10 for land and press set/res and the readout goes black and accepts no further numbers.
Same thing with the unlock sequence. After pressing 1000 and 10 I get "Funktion: -- - -" and enter 19 and press set/res. After that the readout goes black. When I start the car I get "kühlwasser prüfen -- betriebsan leitung" which translates "Check cooling water -- OPERATING INSTRUCTIONS"
Again, this is the 11 button version, NOT the OBC as described in Bentley's, instead it is called "check control/ambient temperature/clock". There seems to be no other mention of it in that overpriced &^&%^$ book.
Are you aware of manuals for the four different versions of this computer found in the e36?
Thank you very much for your help!
post #6 of 7 (permalink) Old 02-24-2012, 01:36 PM
nikmare is on a distinguished road
same problem
i have the same problem on my 97 328i after pressing the 19 the display goes blank. does anyone have an answer, thanks. if not i'll have to learn german
nikmare is offline
post #7 of 7 (permalink) Old 03-17-2012, 02:02 PM Thread Starter
George :-)'s Avatar
Thumbs up Should be a "Sticky" -- solution by Nikmare !
I got it working here's what u have to do------
1. Hold the 1000 and 10 keys simultaneously
2. Press the 1 button until the display shows funktion 01
3. Press the set/res button
4. The display will now show sprache: 1 engl
The display will show other languages but if u want English scroll through (by pressing the 1 button until u see engl1
Good luck let me know how u make out
-------------------------------------- Nickmare rules!
Voila! (pronounced "voe-ILLA" down here. It works like a champ -- should be made a "sticky" under "e36 eleven-button obc" or something like that. Thanks again, this is great!
George :-)
English project Mortiorchis Picture Showroom 4 11-18-2005 08:10 PM
