O2 sensor - BMW Forum - BimmerWerkz.com
Old 01-22-2004, 07:53 AM   #1 (permalink)
rawcar2long is an unknown quantity at this point
Arrow
have '94 325iS 150k miles OBD-1. Two years ago during cold winter day, got a "check engine" light after decending a long hill before car was warmed up. Later I pulled up the trouble code by depressing the accelerator 5 times in 5 seconds and the "check engine " light displayed 1221, which is the code for O2 sensor. Was able to erase the code and put out the "check engine" light. This happen several more times that winter under similar circumstances.
Later I connected a DVM to the O2 sensor, while running, and this seemed OK voltage varying from zero to 0.9 VDC while driving. However during the first few miles after starting, the voltage at the O2 sensor is a steady 0.45 VDC (default voltage supplied by engine computer). This lasts until the engine control computer decides the O2 sensor has warmed up enough to produce a valid reading (takes about a mile or two).
My theory is that while the car was doing the long downhill decent, soon after a cold start, the engine computer switched from the default (sensor warm up mode producing 0.45VDC) to the actual sensor voltage. Since this is a closed throttle situation, coasting down a long hill, the O2 sensor produces near zero VDC. The engine computer sensed this as a bad O2 sensor and lit the "check engine" light.
Now my question: This time, I was not able to reset the "check engine" light. When the trouble code is pulled up (1221), I get repeated codes 1221,1221,1221,..... Never get long flash indicating code all finished so can't reset "check engine" light.
rawcar2long is offline   Reply With Quote
Old 01-22-2004, 09:54 AM   #2 (permalink)
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
I believe your O2 sensor is bad and has a fault in it somewhere. Maybe there are technicalities that are allowing it to give a bad Voltage read out at times and at others is seems normal. I replaced my O2 sensor immediately after I bought it as the CE light was apearing from time to time as well. When I changed the sensor not only did I pick up a much smoother idle, but I also gained better gas mileage as well as throttle response and mid-range torque. I would replace it if you have any doubts before it gets too bad and starts throwing off your air/fuel a lot.
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='http://www.cardomain.com/memberpage/458339' target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1078289877.jpg' border='0' alt='user posted image' />
bimmerfan620 is offline   Reply With Quote
Old 01-22-2004, 10:56 AM   #3 (permalink)
ex owner/admin
Furious's Avatar
just change the O2 sensor, if its acting up then it may be time to change it
O2 Sensor bmwfam123 3-Series (E36) 0 02-25-2005 07:18 PM
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
New Car - Few Problems, Any Help Appreciated. Sagan 3-Series (E36) 8 05-16-2004 09:28 PM
ABS sensor light fault.. Ski Bimmer Talk/Motorsports Talk 6 04-18-2003 08:38 PM
