not starting, only cranking - BMW Forum - BimmerWerkz.com
Old 06-22-2012, 07:20 PM   #1 (permalink)
dudleyduright is on a distinguished road
1995 325 IS
symptoms; was running in the driveway, touched door handle, sputtered and stalled.
Not starting, only cranking
disconnected battery for computer reset. no start.. locked/unlocked door with key... no start
Checked the fuses: Fuses 11,12,15,18 have no voltage. Checked OHMS on crankshaft sensor, seems fine, according to the forums.....
checked the fuel pump: No voltage to fuel pump, used battery charger, removed plug and jumpered it. no start.
did a hopscotch with the relays. Jumpered the #1 relay-fuel pump.. positions 30 and 87 still no start
checked the startability with starting fluid:
it fires and dies with starting fluid so the spark is OK.
out of ideas
dudleyduright is offline   Reply With Quote
Old 06-27-2012, 06:47 AM   #2 (permalink)
could this be a faulty crash control module? Is there a reset for this/where is it located?
Old 07-02-2012, 11:25 PM   #3 (permalink)
Car: 1998 BMW 323is
bpwestmoreland is on a distinguished road
If it is only cranking you are not getting fuel, no voltage to the fuel pump should give you the inclination that is the problem, that little thing is tied into so many wires its not funny, try that and go from there. when you put the key in the ignition and turn it to ACC you should hear the fuel pump engage. If you do not then that is the problem.
bpwestmoreland is offline   Reply With Quote
Old 07-02-2012, 11:26 PM   #4 (permalink)
Car: 1998 BMW 323is
if the fuel pump is bad then the relay is good but there is no power at all....
Old 07-02-2012, 11:30 PM   #5 (permalink)
Thanks,
I will check that tomorrow!
not starting, only cranking dudleyduright 3-Series (E36) 0 06-22-2012 07:15 PM
82 320I - no fire while cranking..... millertyme 3-Series (E21, E30) 4 11-02-2010 06:42 AM
Not Cranking, quit starting... Jedz123 3-Series (E21, E30) 15 12-30-2008 10:47 PM
Any one know the cranking amps on battery YNGRVP 3-Series (E36) 2 05-29-2004 01:28 AM
battery cranking amps jason325i 3-Series (E36) 0 02-11-2004 04:57 PM
