| not starting, only cranking 1995 325 IS
symptoms; was running in the driveway, touched door handle, sputtered and stalled.
Not starting, only cranking
disconnected battery for computer reset. no start..
Checked the fuses: Fuses 11,12,15,18 have no voltage. Checked OHMS on crankshaft sensor, seems fine, according to the forums.....
checked the fuel pump: No voltage to fuel pump, used battery charger, removed plug and jumpered it. no start.
did a hopscotch with the relays. Jumpered the #1 relay-fuel pump.. positions 30 and 87 still no start
checked the startability with starting fluid:
it fires and dies with starting fluid so the spark is OK.
out of ideas |
