Getting my 95 318i on wednesday but I noticed something with the airbag light on the dash. When I turn on the engine it will stay on for a few minutes than goes off. All the cars I've owned before only turned on for a few seconds than goes off. Is this normal for BMWs?
Also when I push down on the rear right wheel it gives me a squish squeak, what can that be?
If it is a sqeek.. it will probably soon turn to a thump.. this is a common problem with E36s..
What your problem is.. is your rear shock mounts... mainly the rubber bushing atop the shock/strut.. has failed.. thus letting it bounce around.. causing the sqeek... and then when it fully fails.. its a thump.. do some research.. you may find replacement from www.rogueengineering.com with lifetime garantees... also I think www.turnermotorsports.com carries them too..
As for your air bag light.. it would be a good idea to get the code read from the car .. because there are a few things that would cause that light to come on...
[snapback]283534[/snapback]
Yea but the strange thing is it goes off after a few minutes so it doesn't actually stay on.
Originally posted by prynce_qt+Jan 31 2005, 10:07 PM--><div class='quotetop'>QUOTE(prynce_qt @ Jan 31 2005, 10:07 PM)</div><div class='quotemain'><!--QuoteBegin-97alpineM3@Jan 31 2005, 08:01 PM are you speaking of the noise or the light?
Les
[snapback]283547[/snapback]
The abs light.
[snapback]283717[/snapback]
[/b][/quote]
ABS= Anti-Lock Braking System - SRS=Airbag
Which one is lit?
Also I had that squeek, replaced shocks with bilstein and reinforced mounts and good to go..no more squeek
well actually its kinda weird that i have the srs air bag light and the squeek in the samw wheel.???!?!?!?... but i doubt it has anything to do with the airbag. prob just a coincedence.
Originally posted by prynce_qt@Jan 31 2005, 04:39 PM Getting my 95 318i on wednesday but I noticed something with the airbag light on the dash. When I turn on the engine it will stay on for a few minutes than goes off. All the cars I've owned before only turned on for a few seconds than goes off. Is this normal for BMWs?
On the airbag light, chances are the instrument cluster was removed without disconnecting the battery. I do not know how to reset this light with any at-home methods, but wouldn't mind finding one (I've tried the service reset jumper without luck). I would still have it checked out or reset by a shop as I won't guarantee there isn't something else wrong (and take no responsibilty of personal injury).
I have the same issue after replacing the backlight bulbs after removing the cluster.
