noob injector question - BMW Forum - BimmerWerkz.com
Old 06-24-2008, 01:52 AM   #1 (permalink)
dumguywithm60@yahoo.com's Avatar
Car: 1999 BMW 328is
dumguywithm60@yahoo.com is on a distinguished road
Send a message via AIM to dumguywithm60@yahoo.com
is the green nozzle necessary for the piston to fire? i was pulling out my fuel rail yesterday and the tip of my injector came off, no idea where the nozzle went but found the oring sitting on top of a valve after i removed the intake manifold (those lower brackets couldnt be harder to get to) however once i fired it up it im pretty sure a piston wasnt firing, not the nice idle im used to, now 4 fires, a space, then a shuttering fire of the last piston. im guessing the green nozzle is either needed or i really screwed something up while getting the oring, while putting it all back together one of the injectors came out a bit and squirted gas everywhere (surprisingly gas doesnt burn in your eyes) i know thats cuz the line is pressurized by the pump but is that enough to break an injector? because besides that the only difference now from how it was is the nozzle being gone. ive heard from a few people that it isnt needed but theres definitely something wrong with the way its firing. im guessing that the nozzle makes the fuel a vapor instead of just a drip and thats why its not firing, ive only ad the car started a good 30 seconds with this but should the gas not be igniting instead of not being delivered and just pooling, having it detonate wouldnt be good, its my daily driver so any help would be amazing. right now im in the process of getting a new one but thats not gunna be for a few days, if anybody has a stock injector they arent using pm me. thanks
dumguywithm60@yahoo.com is offline   Reply With Quote
Old 06-24-2008, 10:11 AM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Arrow
the nozzle you lost is part of the atomizer design... yes it is an integral part of the injector for it to work properly. If you lost it and it found itself into the valves, it's possible it is holding a valve in open position or interfering with it's operation - thus, your complain that a cylinder isnt working.
you are also correct. an injector that drips fuel instead of atomizing it will cause a rough idle/sputter.
to replace that bad injector, you'll need to remove the manifold anywayz; so i suggest that when it's all out in the open, u carefully inspect and see that the missing piece isn't in your valves(the intake valves in particular because of the suction). Additionally, u can also open the valve covers and turn ur crankshaft by hand and see to it that all valves are operational before u put everything back in order
Good Luck...
fuel injector question ponyboy87 3-Series (E21, E30) 1 10-10-2006 11:55 PM
Noob Question... Sorry! 325eXTATIC 3-Series (E21, E30) 5 03-20-2006 09:14 PM
This might be a noob question. ldsbeaker 3-Series (E21, E30) 7 02-19-2006 12:01 PM
Noob Question Probably spieluhr 3-Series (E36) 11 10-30-2004 11:37 PM
Shark injector question ? BraZa04 3-Series (E46, E90) 3 03-01-2004 09:47 AM
