Someone recently recommended that I switch out my iron block for the m52 block and keep my m50 head and forged crank (let him know about m50 rods, thx trig). So aside from weight what would the advantages be? Does it really bolt up? Anyone have any experience with this?
__________________ "I would not know what the spirit of a philosopher might wish more to be than a good dancer."
- Friedrich Nietzsche
1980 635csi Euro . . . Current
1985 535i . . . Soon to be parted out
2001 Subaru Forester . . . DD
Ok, maybe a simpler question. If I go FI in the future will I regret having an aluminum block?
well if you want to go with boost, then the non-vanos block is God. It's heavier for a reason, it's got more meat, which means it's stronger which means you can run more boost. The whole reason, as it turns out, that the non-Vanos engine is so much more beefy is because it doesn't have knock sensors. No, instead, BMW opted to just make it tough enough that they don't have to care about knock. That's why they are bulletproof.
Addicted to Speed Since 1997 Founding member of the GreenDragon Poo Flingers Club
also, the M52 is NOT an aluminum block if you live in the United States.
Edit: Because the European countries used Nikasil as a liner in the aluminum blocks, and nikasil has marginal reliablility using high sulfur gasoline, they opted to use the same Iron block as was used in the M50.
Got it. Doesn't mean I can't keep thinking of dumb questions though.
I'll try and leave out the real obvious ones. Same block=same bore, therefore deeper stroke to get to 2.8. I was leaving work and didn't give it any thought.
