Noisey When A/c Is Switched On - BMW Forum - BimmerWerkz.com
Old 07-26-2005, 09:34 AM   #1 (permalink)
BMW Aquarium is an unknown quantity at this point
I just bought a 96 328IS and the only problem is with the A/C.
When I'm not running the A/C everything is quiet and sounds great. When I turn on the A/C I can hear something that sounds more like a rattle.
(I know what bearings sound like when they go bad.)
Anyone have any ideas about this? Blwer motor was just replaced before I bought it.
Thanks
BMW Aquarium is offline   Reply With Quote
Old 07-26-2005, 12:31 PM   #2 (permalink)
SinSeven's Avatar
SinSeven is an unknown quantity at this point
It could be the compressor. I'm kind of experiencing the same problem, but mine is more of a "hissing" noise. Hope you get the anwer you're looking for.
SinSeven is offline   Reply With Quote
Old 07-26-2005, 03:47 PM   #3 (permalink)
BMW compressors ESPECIALLY get noisy with age. Sometimes it means they are going bad - sometimes it means they are simply old, but will last a while.
It's nothing to worry about unless it's on its way out - usually.
You can sometimes tell if its on its way out if the clutch on it starts to slip OR lock and cause belt squeak for a breif moment, or if cool air cuts out for a few seconds at a time, etc.
Old 07-26-2005, 10:54 PM   #4 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Hmmmm. I have the same rattle, and I have heard it comeing from other E36s as well. I guess I will just let it be. You can get a new compressor from eBay for real cheap. http://cgi.ebay.com/ebaymotors/AC-Compress...1QQcmdZViewItem
Replacing it is not simple, so labor may cost you a bit. I will jst live with the rattle. I'll change it if it goes out.
Turkey Fleet Bond Holder
Old 07-27-2005, 04:38 PM   #5 (permalink)
cymorg's Avatar
cymorg is an unknown quantity at this point
Send a message via ICQ to cymorg Send a message via AIM to cymorg Send a message via MSN to cymorg Send a message via Yahoo to cymorg
mine also makes sortof a hissing or whining noise when the a/c is on.
it blows decent amounts of air... i can live with it i suppose.
cymorg is offline   Reply With Quote
Old 07-27-2005, 08:16 PM   #6 (permalink)
I was talking to my wifes step father and he told me to put soapy water on the belts.
If that doesn't work then look to the tensioner and idoler.
Lastly the compressor.
As soon as I get back to KS I will try and see if it works.
Old 07-27-2005, 11:21 PM   #7 (permalink)
drz
drz's Avatar
Car: zhp
The soapy water thing is not really a fix. Check your belt for cracks or any other damage. If you notice anytyhing, replace the belt with a new one.
Old 07-27-2005, 11:21 PM   #8 (permalink)
drz
drz's Avatar
Car: zhp
I had the rattle on my car, replaced the belts, and still have the rattle.
Old 07-28-2005, 05:05 PM   #9 (permalink)
cymorg's Avatar
so will replacing the belts take away that hissing and moaning noise that I have?
Old 07-28-2005, 07:17 PM   #10 (permalink)
camnipotent's Avatar
camnipotent is an unknown quantity at this point
Send a message via AIM to camnipotent Send a message via MSN to camnipotent
I don't know for sure if that will work. I've had them all replaced and I get the compressor sound every time the A/C switches on, and from reading the other posts, it sounds like it is common. Every car, obviously, will make noise when the A/C switches on, but if it is obviously louder than it should be, take it tothe dealership for a quick quote. They shouldn't cost anything.
<span style='font-size:8pt;line-height:100%'><span style='color:blue'>1998 BMW 323is Coupe, Black
Manual
18&quot; M3 Hyper Silver Rims
2 12&quot; Rockford Fosgate Subs; Sealed
1.0 Farad Capacitor
800 Watt 2-Way Rockford Fosgate Amplifier</span></span>
camnipotent is offline   Reply With Quote
Old 07-28-2005, 09:21 PM   #11 (permalink)
cymorg's Avatar
yeah right every time i goto the dealer they charge me like craaazy
Old 07-28-2005, 10:33 PM   #12 (permalink)
I'm talking about the quote will be free, not the service...hahaha. I know they would figure out what the problem is, and then you can get it fixed if you do it yourself for 1/3 of the price.
Manual
1.0 Farad Capacitor
Old 07-29-2005, 09:29 AM   #13 (permalink)
Gkamysz is an unknown quantity at this point
Yeah, mine is loud outside the car, kind of hiss, no rattles though. The rattle could simply be a heat shield which is loose. When the air is on, the engine tends to shake more at idle. Does it rattle at 1000 RPM or more? I don't think mine is cooling very well at this point, but haven't checked the coolant yet.
Greg
97 328iS, Manual, Stock
Gkamysz is offline   Reply With Quote
Old 07-29-2005, 10:14 AM   #14 (permalink)
A/C units always work better when you are moving anyway.
Manual
1.0 Farad Capacitor
Old 07-30-2005, 02:13 PM   #15 (permalink)
I'm not sure if my A/C runs smoother at higher RPM.
I'm currently on vacation in Oregon. I will check on Sunday when I get back into town.
If I bought the part, how much would it cost to have a local shop swap out the old part and install the new one?
how do you get the a/c off ? j123crx 3-Series (E21, E30) 1 10-15-2005 04:03 PM
Noisey Lifters? Clint_M 3-Series (E36) 2 11-16-2004 10:20 AM
ignition switched Power points under the hood Zq-8_dawg 3-Series (E36) 3 07-24-2004 11:40 AM
NOISEY E46 328ci leather sports seats thommo41 3-Series (E46, E90) 1 05-18-2004 01:04 PM
