Noise at rear differential - BMW Forum - BimmerWerkz.com
Old 07-31-2007, 11:35 PM   #1 (permalink)
muk5 is on a distinguished road
Unhappy Noise at rear differential
I have this noise coming from the rear differential only under load and
at pretty much between 40-50 mph .when i remove my foot off the gas
pedal ,the sound goes away .
i'm pretty much sure it's not the wheel bearing or the guibo flex coupling.
it sounds like something is out of balance .
Can anyone suggest which bearing would make that noise?
or common bearing noise?
Any advice would be much appreciated ?
muk5 is offline   Reply With Quote
Old 08-01-2007, 01:31 PM   #2 (permalink)
Montizzle is a glorious beacon of lightMontizzle is a glorious beacon of lightMontizzle is a glorious beacon of lightMontizzle is a glorious beacon of lightMontizzle is a glorious beacon of light
If it sounds like a "CLUNK" or "BANG" noise, then you have prolly broken the diff bolt. Its a very common problem.
99 Dakar M3
|Conforti|Sharked|TC Kline SA|DEPO||BBS|M50 MANIFOLD|UUC|DDM|SPARCO|OEM X BRACE||SSK|ECS TUNING|MISHIMOTO|
Montizzle is offline   Reply With Quote
Old 08-01-2007, 02:26 PM   #3 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
If the noise is steady under load and constant crusing but goes away when you lift off the gas its probably the input bearing in the nose of the diff.
My M50 Powered E30 Page
Noise in your system? da_bull Audio and Electronics 2 05-15-2013 03:27 AM
Defeating the Noise beast! ~JT Audio and Electronics 1 08-16-2006 09:58 AM
Broken rear spring/ noise...arrgggh kylek325i 3-Series (E36) 8 01-05-2006 12:19 AM
Differential Groaning noise (FIXED!) shield 3-Series (E21, E30) 0 09-12-2004 04:56 AM
