No spark at #4 cylinder - BMW Forum - BimmerWerkz.com
Old 06-13-2011, 08:26 AM   #1 (permalink)
rwalker is on a distinguished road
My 1993 325i is having trouble
Well hello everyone , my problem is i changed the plugs, i changed the coil packs due to a misfire in the engine.I ve recently put on new mass air flow and cleaned the I-C-V. The misfire is still there. I have to believe at this point the only thing left would be wiring from the #4 cylinder. I got a feeling this may lead me to the ecm. please help if you have any feedback. Cylinder #4 still has no spark
rwalker is offline   Reply With Quote
Old 06-14-2011, 05:20 AM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Is there a crank position sensor on your engine? Could that be the issue? Have you confirmed visually that have no spark, or is just that cylinder for isn't firing? My point is could it be a dead injector?
Riding in style
Old 06-14-2011, 01:00 PM   #3 (permalink)
no i have not confirmed by seeing no spark, only using the method removing wire connection to it and there was no change. and yes i do have a crank position sensor on my car. Thank you for your reply
Old 06-14-2011, 01:58 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
You need to remove number four plug and connect to its coil, earth it to engine to eliminate plug/coil as fault...
If no spark = Electrical
Good spark = Fuel Injector or valve
DAZ
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 06-14-2011, 04:45 PM   #5 (permalink)
brettski's Avatar
If you haqve a spare plug laying around (one of the old ones that you recently changed out is probably good enough) use one of them instead of removing the new plug from the head. It may avoid a small fire from fuel being blown out through the plug mounting hole and igniting on the spark. Hopefully its just an injector issue.
If you have a mechanics stethoscope listen to each injector to see if you can hear it firing, otherwise try screwdriver by putting the pointy tip against the body of the injector and the blunt handle in your ear.
Good luck
Riding in style
Old 06-16-2011, 07:12 AM   #6 (permalink)
thanks for the feedback you guys are great , going outside to try your method now. Also thanks Brettski for the safety tip
Cylinder Head STEPHEN WILKERSON 3-Series (E36) 2 04-09-2010 01:41 AM
Future BMW 1-Series and 3-Series to Get Turbocharged 3-Cylinder and 4-Cylinder Engine administrator BMW News 6 05-16-2009 02:14 AM
Cylinder psi? kris 1,6,7,8 - Series and Mini Cooper 0 02-11-2009 12:21 PM
4th Cylinder Down! WarNox 3-Series (E36) 6 02-02-2006 01:07 AM
Misfire Cylinder 5 gthoman 3-Series (E46, E90) 19 02-23-2005 02:07 PM
