no power - BMW Forum - BimmerWerkz.com
Old 06-26-2004, 11:57 AM   #1 (permalink)
peter1loftin is an unknown quantity at this point
Smile
can some one please help. my 318is has lost all its power and it is using loads of petrol it idles between 500 + 2500 revs the o2 sensor is stuck on high the garage told me but they say that it would not make it do all of the things it is doing can any one help?
peter1loftin is offline   Reply With Quote
Old 06-26-2004, 12:24 PM   #2 (permalink)
Kevin325i's Avatar
For the idling clean your ICV valve. There's stuff in the how to's section.
Kevin
Kevin (President TBEA)
Old 06-27-2004, 01:36 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
I'd take it to a dealer.. and have them look at it.... honestly.... its not worth trying to figure out when there are atleast a good 20 things that could be your problem.
1997 E36 M3 1990 E30 325i
Old 06-27-2004, 05:26 PM   #4 (permalink)
Looky is an unknown quantity at this point
read the fault codes... like 97alpineM3 said, there could be different problems
but you can do some tests.
...check the resistance with a multimeter -->
- of the injection nozzles
- of the throttle valve
- your mass airflow sensor
- your ingition coils
in most cases when the motor is cold an you drive with low rpm the motor runs good. if he goes warmer, you run with higher rpm and the motor runs retty shit it's a damage in your ignition coils (resitance runs up caused of increased temperature-> igniton voltage goes down)
greets
Looky
<a href='http://www.projekt-e36.de' target='_blank'><span style='font-size:9pt;line-height:100%'><span style='color:red'>www.projekt-e36.de</span></span></a>
<img src='http://www.projekt-e36.de/webpic.jpg' border='0' alt='user posted image' />
Greets from Germany
__________________________________________________ _
changed to M50B25; Mahle pistons;Spesso headseal; polished cylinder head; mocal 19R oilcooler; M3 oilfiltercase; dbilas cam shafts, dbilas EEPROM; TeZet sync. header; HJS metall catalytic converters 2x150 cells; G-Power rear muffler; 8,9lb fly-wheel; OMP clutch; 55.73psi fuel regulator; K&amp;N 57i; SD200 gearbox; 3:45 diff; ..... KW coilover kit - 2; E46M3 front-bumper; Rieger Infinity rear bumper; M3 sideskirts; X-brace subframe; 9.5x17ET1+10,5x17ET14 rims; ...
Looky is offline   Reply With Quote
New Hu Has No Power jshearer Audio and Electronics 3 12-30-2004 07:56 PM
Best Kind Of Headlight Bulb? all4isu 5-Series (E12,E28, E34, E39, E60) 6 10-18-2004 02:26 PM
power pulleys, re they really that bad? the///man 3-Series (E36) 1 10-18-2003 09:12 AM
