No Heat - BMW Forum - BimmerWerkz.com
Old 03-09-2004, 03:04 PM   #1 (permalink)
cmoore is an unknown quantity at this point
I have a 1993 325i. All knobs (upper Cold/hot, and lower 2 temperature knobs)are turned to hot (Red). I flused the system to assure no air in the system and checked thermostat.
Is this a fuse, relay, heater control valve, cable or other problem. HELP BRRRRRRRR cold.
cmoore is offline   Reply With Quote
Old 03-10-2004, 02:41 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
hard to tell , how is the temp gauge? if its ok then its probably a climate control problem
if the temp gauge is off then its probably a mechanical problem (ie water pump , leak, thermo etc)
Heat only coming out of drivers side Yankees368 5-Series (E12,E28, E34, E39, E60) 14 12-06-2005 01:12 PM
cai heat shield nobrakese36 3-Series (E36) 3 09-19-2005 04:22 AM
Removing Heat Sheild Live_the_Curves 3-Series (E36) 9 03-09-2005 11:56 AM
Hey Guys, Just A Quick Question Regarding My Heat bimmerfan620 3-Series (E36) 6 10-29-2004 02:52 PM
no heat 1991 BMW 318i will1506 3-Series (E21, E30) 9 02-27-2004 10:58 AM
