No Crank No Start - BMW Forum - BimmerWerkz.com
Old 10-12-2007, 08:55 AM   #1 (permalink)
VertE36 is on a distinguished road
Unhappy No Crank No Start
I have a 1996 328I Convertible I was driving this morning went over a bump the A/C fan went off, A/C module lights stuk in position stayed on, and the On Board Computer Turned off. When I got to work I turned the car off and now it won't restart. I get all the lights, (no OBC or A/C lights) headlights bright, NO CRANK, NO CLICK, NO START. I just bought the car yesterday and its started 5 times just fine, now WTF? I am stuck at work please help!!!
Oh and I could not compression start this 5 speed, I may not have been rolling fast enough.
It does not have an alarm that I know of just keyless entry
Theories: I dont have 9.6 volts so the computer wont come on?
It has a kill switch? but where?
I have no owners manual so I have no relay map.
Questions: Anyone have a map of the relay's?
Anyone know where the "other" fuse box(s) are?
Anyone know where a kill reset switch is?
Please help
Chris
VertE36 is offline   Reply With Quote
Old 10-12-2007, 02:50 PM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
...that sucks man do you have a volt meter to seel the voltage at the battery but if the headlights are bright battery should be fine you might of lost a relay.... that suck about just buying it and this happends....
1992 318i Coupe parts car
I am Captain Obvious
Old 10-14-2007, 02:23 PM   #3 (permalink)
diag
It has 12.5 volts
i reset the puter' 2 min no batt then reconnected batt 15 min in key position 1
i tried to push start it, no go
i swapped all realays
i have a blown fuse for the clock 31
i disconnected the battery, grounded the ecm/pcm turned on the headlights to drain capacitors eveywhere, took out pcm, looked for pulled harness pins. shook it for loose shit, all good, hooked back up, reconnected battyery
i hold FAA Airframe Power plant licenses and FCC avionics
i hold the ase master technicians certification
i am certified in ford and Chevy
my scanner cant do euro, that will change.
its at the dealer now, Im getting 'autotap" for my laptop...
help if you can and I will post.
chris/Vertikill/VertE36
still won't start mherbert 1,6,7,8 - Series and Mini Cooper 5 10-05-2006 12:39 PM
328 wont crank or start ritrka 3-Series (E36) 2 09-17-2006 06:47 AM
My 323 will NOT start!?! WTF, guys need your help again! BMerViXeN 3-Series (E36) 8 03-07-2006 05:38 PM
323i Wouldn't Start TRuckee 3-Series (E46, E90) 8 12-04-2005 01:41 PM
2001 325ci Won't Crank, Won't Start, Battery Good laurie325ci 3-Series (E46, E90) 4 06-14-2005 01:05 AM
