No Battery Voltage to Starter - BMW Forum - BimmerWerkz.com
Old 01-07-2006, 01:13 PM   #1 (permalink)
singring is on a distinguished road
My daughter's 1995 318i crapped out again. She said the idle was a little erratic, then the car stalled. The car had been running for about half an hour by that time, so it was at operating temperature and she had no problem initially starting the car this morning. After the stall she could not get the starter to turn over.
I tried to start it, and although the ignition key turns fine, and the dash lights come on, at the third ignition position nothing happens. There is no relay, or solenoid noise, no "clicking" sound...nothing. I have checked the fuses, and they are fine.
Yesterday, I took her car for a wash, but was careful not to get too much water on the windshield area above the DME housing. The production date of the car is May 1995, and BMW says that the DME flooding problem was fixed by that production date, but I am still careful about that anyway.
Yesterday, I also sprayed a little graphite spray into the ignition because occasionally the ignition key would not turn in the ignition. Now the key turns fine, but could I have damaged the ignition lock set by using that spray? Would that have caused a poor electrical connection in the ignition?
This car has been running fine for the last two weeks. Before that, the ignition coil-pack had burnt out on cylinder #2, which toasted a transistor in the DME. The ignition coil-pack has been replaced, and I bought a DME from an auto salvage. I exchanged the EPROM chip for the EPROM chip from the original DME, and all worked well, until today.
One other thing, before we bought the car 2 months ago, the starter had been replaced, however, I don't think there is any voltage getting to the starter relay, or the starter now.
Any help would be appreciated. Thanks
singring is offline   Reply With Quote
Old 01-07-2006, 01:46 PM   #2 (permalink)
kyle_baker's Avatar
kyle_baker is an unknown quantity at this point
Send a message via AIM to kyle_baker Send a message via MSN to kyle_baker Send a message via Yahoo to kyle_baker Send a message via Skype™ to kyle_baker
check to see that the alternator is charging the battery properly, also maybe try cleaning the ICV (Intake Control Valve, fixes some idling issues) here is a DIY link... http://www.bmwe36tips.20m.com/unstable-idle.htm
hope that helps!
kyle_baker is offline   Reply With Quote
Old 01-07-2006, 04:05 PM   #3 (permalink)
tomctx's Avatar
According to the Bentley.
The starter relay and the starter immobilization relay are behind the left footwell speaker grill or left footwell. Also check fuses #26 and #28.
Old 01-07-2006, 05:01 PM   #4 (permalink)
Gator is an unknown quantity at this point
As usual in these cases suspect the battery first. Try jumping the car. If the car still won't turn over, temporarily replace the battery with a known good one. If the car still won't turn over, and you have checked the fuses, begin looking at the wires from the battery, particularily the ground wire for corrosion and breaks. That should solve the problem, but if not you can then begin looking at the ignition switch etc.
Years ago I had exactly the same thing happen to me. Car started, ran for half an hour, stopped for gas, wouldn't start. The battery had developed an internal short and was so dead it wouldn't even allow the car to be jumped with a massive AAA system. Went to alot of trouble and expense before I replaced the battery and solved the problem. Learned my lesson.
Gator is offline   Reply With Quote
318i-Not charging Hypnogaja 3-Series (E21, E30) 15 10-27-2004 03:18 PM
Help - Battery Light Is On (again) Pegasus 3-Series (E36) 6 10-01-2004 11:14 AM
battery & Blue Lights pk_usf 3-Series (E46, E90) 0 10-20-2003 02:09 PM
