Take the fuel pump fuse out. In my fuse box I believe it was fuse #18. Let the car run till it stalls/dies. Then disconnect the fuel lines on either side of the fuel filter (reduces fuel spilled).
You can run some fuel injector cleaner or take them off an clean them with brake clean. Cleaner can be ran mixed with fuel in the tank or directly from the bottle by disconnecting the fuel line.
Originally Posted by german-speed-demon
A little bottle of Techron Injector Cleaner plus 7 gallons of gas every 1000 miles will help clean injectors and the fuel system. This does not replace the periodic clean up like you wish to do. What you wish is to clean (or have cleaned) the injectors with an ultrasonic washer. Check with your mechanic.
which fuels injector cleaner is the best for bmw ? i want a good want. cause i have to replace fuel filter tooo
I'd reccomend NGK plugs. My 94 325i had bosch 4 ground plugs that were new when I bought it and I switched to ngk and got about 2mpg better. I've always had good results with NGK plugs in all of my vehicles.
