Newbie w/93 325 e36 Oil questions - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 06-29-2008, 08:03 PM Thread Starter
VA325 is on a distinguished road
Hi all,
Recently purchased a 1993 325i e36 for my son. I'm not new to BMW's, worked for BMW for a few years up to 1976, after leaving Porsche. Currently I drive a 1987 528e with only 137k miles, excellent car, will probably outlast me. Anyway my question about the 325 pertains to oil: type and quantity. Haynes repair manual recommends 20-50 weight, 6.8 quarts when change includes filter. I went with Castrol GTX 20-50 since it is the same as I use in the 528/M20. I ended up pouring in 8 quart's to get the correct reading on the dip stick. Was the hayne's manual wrong? With that volume of oil I would expect more than 3000 miles between changes, am I correct? Would synthetic be a better choice. What does the factory recommend? All replies appreciated.
Bob in VA.
VA325 is offline
post #2 of 4 (permalink) Old 06-29-2008, 10:02 PM
darkhorse737's Avatar
Quoted: 2 Post(s)
recommended volume with oil filter change is 6.5liters/5.7 qts
However, the latest BMW Technical Service Bulletin also specifies that ideal oil level should be within the upper third level of that space between MIN & MAX marks.
* i have actually experienced putting 7.5ltrs to achieve full level, and then that drops a little bit after you have run the engine a few mins, because the oil filter takes up about half a qt or so :-)
choice of multigrade viscosities is dependent on the average temp in your area. If u live in colder climate/s choose the lighter grade... if u are in a place that has near tropical weather, choose a heavier grade.
If you are diligent with the 3000 miles oil change, petroleum based oil and synthetic presents minimal difference.
darkhorse737 is offline
post #3 of 4 (permalink) Old 06-30-2008, 07:07 AM
bimmerguy82's Avatar
bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute
Originally Posted by VA325 View Post
Hi all,
Bob in VA.
My 92' 325i has always taken at least 7 qrts to fill plus some after you let it run. I personally believe full synthetic is the way to go. I use Mobil 1 15-50W for summer and 10-30W for winter.
P.S. Get a Bentley manual, it will save your life. (Haynes not so good)
BMWcrazy
___________
-Joshua
BMWCCA member#407674
bimmerguy82 is offline
post #4 of 4 (permalink) Old 06-30-2008, 07:17 AM Thread Starter
Interesting, it took a full 8 quarts with a new filter, still did not reach the upper mark on the dipstick. I try to maintain the 3000 mile change, I base it more on color.
Thanks for all the replies.
VA325 is offline
Hello From A Newbie And Some Questions! Hawaiiannights M-Series (M1, M3, M5, M6) 2 05-16-2005 11:53 AM
Newbie With Questions djianlaverick 3-Series (E36) 3 03-18-2005 10:21 PM
Newbie Questions celicaxx 3-Series (E36) 3 01-03-2005 05:52 PM
Newbie Questions. hockey_fan 3-Series (E36) 7 10-06-2004 05:41 AM
Newbie needs help w/ 325 mohan_raj_nair 3-Series (E46, E90) 5 02-05-2004 07:57 PM
