New Rims problems :( - BMW Forum - BimmerWerkz.com
Old 12-29-2003, 02:05 AM   #1 (permalink)
akolang's Avatar
akolang is an unknown quantity at this point
hi (noobie here ) i have a 96 328i (complete stock, and automatic, not my first choice but at the time im dying for a bimmer :P hehe) ... well the thing is i got new 18" and the car seems to accelerate slower.. getting lower mpg's use to be around 20-22mpg now only 17-18.5... also everytime i accelerate and reach around 20-25mph it feels like im switching gear.... i was wondering if anyone else who changed their rims had this happen to them... is it normal?? bad for the engine or what???? friend said have it recalibrated... but i wanna know from ya'll bimmer owners anyways any idea what's up... will it damage my engine...??? well thanks in advance!! -Ron
<img src='http://www.bmw-forums.com/forum/uploads/photo-2215.jpg' border='0' alt='user posted image' />
My 328i
akolang is offline   Reply With Quote
Old 12-29-2003, 02:46 AM   #2 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
welcome
first off, to plus-size rims and tires, you have to get the right size. its mainly the tires that does it. a 235/40/18 tire will be taller than a 235/30/18 tire. different cars require different sizes; you should check your owners manual to see what size tires you need. my E46 takes 235/40/18 for 18" rims. Now why is this important...well if your tire's overall diameter is wider OR narrower than stock, you will have wrong readings of speed and that will yield to wrong mpg numbers. Try measuring the diameter of both the stock tire and the new tire (overall tire diameter) to see if they equal up. it should be +/- an inch.
another is the fact that your rims are wider; wider the rim, more force is needed to turn that rim. this could slow you down. (the general rule is, small diameter wheels accelerate faster, but has low top speed : larger diameter wheels accelerate slower, but has a higher top speed)
and finally, the weight of the rim greatly decreases speed and accelation. there are reasons why rims can be cheap or expensive; style is one factor, but one major factor is weight. alot of aftermarket rims are heavier than stock; creating more weight for the car thus using more power from the engine to turn the rim. this also could slow you down as well.
hope that helped a bit
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
Old 12-29-2003, 03:37 AM   #3 (permalink)
Syn3rgY is an unknown quantity at this point
Maybe your speed sensors are messed up or something. I agree with your friend, get it recalibrated.
Syn3rgY is offline   Reply With Quote
Old 12-29-2003, 07:22 AM   #4 (permalink)
roloson's Avatar
roloson is an unknown quantity at this point
Here is a simple calculator to figure where you ended up in comparison with where you started. For example the 19s I got on my M3 actually lowered the gear ratio slightly. Thousands of a percent. Very slightly. The engineers at BMW did their home work and went to a shorter sidewall. By doing that they did not need to run a different rear gear. IE keep manufacturing costs down. You pick up some handling do to less side wall flex and you get a larger contact patch in my case. If you are way off and performance is a big issue a gear change is not a huge deal. An experienced garage can do it in a couple of hours.
http://www.car-videos.com/info/tirespecs.asp
Shoot Bear When Bear In Season
2004 M3 LSB SMG II Rolling on 19s
&quot;The Thrill&quot;
roloson is offline   Reply With Quote
Old 12-29-2003, 08:31 AM   #5 (permalink)
trinidon2k's Avatar
trinidon2k is an unknown quantity at this point
Send a message via AIM to trinidon2k
did u get some cheap crap ass replica rims that are like 60 pounds each?
trinidon2k is offline   Reply With Quote
Old 12-29-2003, 09:37 AM   #6 (permalink)
akolang's Avatar
ah no its not some replica :P , i got adr cypher.... so can it be fixed having it recalibrated...???
My 328i
Old 12-29-2003, 09:45 AM   #7 (permalink)
akolang's Avatar
thank you .... ohhh i see... but is it bad for the engine though? since it needs more power and such to turn the wheels??? thnx
My 328i
Old 12-29-2003, 10:19 AM   #8 (permalink)
Scarface's Avatar
Scarface is an unknown quantity at this point
Send a message via AIM to Scarface
Anytime you plus size your wheels, you run the chance of getting something heavier and possibly bigger in diameter than what is stock..I have 19's on my car and it did seem a little slower but damn they look good! I would check and see if you can get it recalibrated...Alot of times aftermarket wheels are heavier than stock ones, that will slow a car down...
-1998 BMW 540i6(Axis Penta 20's,M5 shadow grilles,trunk lip,led tails,oem front lip,PIAA lighting)
-2002 Cadillac Escalade(Zinik Luina 22's,OEM HID upgrade)
Scarface is offline   Reply With Quote
Old 12-29-2003, 10:51 AM   #9 (permalink)
ex owner/admin
Furious's Avatar
to keep going with scarface said, plus sizing wheels will usually always add weight thus making the weight to power ratio different (you need more power to turn heavier wheels) now your mpgs may be off as well as your speedo because you may or may not have the correct overall diameter rims and rubber on your car causing all the calculations to be thrown off.
Old 12-29-2003, 11:42 AM   #10 (permalink)
akolang's Avatar
ohhhh alright i get it thanks guys guess i need to up the power of the car , i did alot of the exterior stuff already but none to boost power yet =\ heres a pic, what do u guys think? oh and for the rear is it knoticable that i didnt use an m3 bumper.. just a stock 328i and attatched a diffuser??? :P
New Rims problems :(-cars.jpg
My 328i
Old 12-29-2003, 11:44 AM   #11 (permalink)
ex owner/admin
Furious's Avatar
looks good but your gonna need to lower the car soon. too much fender gap, otherwise a very nice start.
Old 12-29-2003, 11:47 AM   #12 (permalink)
akolang's Avatar
ya soon as i get some money im thinkin of lowering it... still thinkin if i should change the rear bumper to real one, it doesnt seem to be much difference... oh well if i get the money i may hehe thanks
My 328i
Old 12-29-2003, 11:51 PM   #13 (permalink)
BlackTape's Avatar
BlackTape is an unknown quantity at this point
Send a message via ICQ to BlackTape Send a message via AIM to BlackTape Send a message via MSN to BlackTape Send a message via Yahoo to BlackTape
Originally posted by woobiee@Dec 29 2003, 05:26 AM
welcome
wow pro write up
<img src='http://www.satchmo.com/cashmoney/btymers.jpg' border='0' alt='user posted image' />
<span style='font-family:Impact'><span style='font-size:21pt;line-height:100%'><span style='color:red'> GANGSTA Tape</span></span></span>
BlackTape is offline   Reply With Quote
Old 12-30-2003, 07:22 AM   #14 (permalink)
PhiLLaY is an unknown quantity at this point
hey how wide are your 18s? can you please tell me if they scrub against your guards? (fenders) thanks~!
PhiLLaY is offline   Reply With Quote
Old 12-30-2003, 09:34 AM   #15 (permalink)
akolang's Avatar
18x8.5, and no i dont think it rubs against it :lol:
My 328i
Fs: Binno 930 18" Chrome Rims And Tires chakorules Wheels and Tires 1 06-29-2005 11:16 PM
FS: JDM Altstadt 1 Rims (Multi 3pc) cuhrupt Classifieds Sell & Buy 1 08-19-2004 04:07 AM
18" inch, Fittipaldi Diablo Rims - Tires swank Classifieds Sell & Buy 5 08-15-2004 01:43 AM
Anybody Interested in some After-Market Rims pshu007 Classifieds Sell & Buy 5 03-03-2004 08:54 PM
