New Clutch - BMW Forum - BimmerWerkz.com
Old 12-11-2004, 01:52 PM   #1 (permalink)
Black318IS is an unknown quantity at this point
Alright, so i put my new clutch in today and everything is done. I get into my car and now the clutch pedal is like nothing is there at all. I blead the clutch and still nothing. can anyone help? i really need this fixed now
Black318IS is offline   Reply With Quote
Old 12-11-2004, 05:34 PM   #2 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
Make sure you got enough fluid and when you bled the system dont let any air in. Have a person push down the pedal, open valve real fast, and close it. You have to do this many times, inorder for the air not to get back in. After you bled it pump the pedal a few times. I just changed my clutch too, and thats what I did. If that doesnt help maybe you have a bad slave cylinder?.. Good luck.
theruss1an1 is offline   Reply With Quote
Old 12-11-2004, 06:51 PM   #3 (permalink)
supark is an unknown quantity at this point
Yeah, you just need to bleed the system.
If that doesn't work then I agree with theruss1an1, your slave cylinder has probably gone bad.
supark is offline   Reply With Quote
Old 12-12-2004, 12:23 AM   #4 (permalink)
Kevin325i's Avatar
Check the slave cylinder bye taking off the two bolts and looking to see if the plunger is still on it. If you didn't get it to set in the release fork then the first time you press the clutch the plunger shoots out.
Have you tried starting the car? It might just be a lack of pressure from sitting or bubbles that are in the slave (even after bleeding).
Kevin (President TBEA)
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 05:22 PM
Clutch Kevin325i 3-Series (E36) 13 08-06-2004 12:09 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
E36 M3 UUC Flywheel Wrong Clutch Becherert 3-Series (E36) 1 03-09-2004 01:39 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
