Never have I ever.... (HELP) - BMW Forum - BimmerWerkz.com
Old 04-12-2006, 01:01 AM   #1 (permalink)
Car: E30 318i, E30 318is, E30 M3
dvmotorsports is on a distinguished road
Exclamation Never have I ever.... (HELP)
I took the 318is to the wash today to get it cleaned up for the new owner. Well once the rinse cycle came on and a bunch of water went into the mesh area at the base of the windshield the car died. So I sat there for two hours until i could get it to start. Finally!
Here is the problem, it sputters unbelievably. Under accel, decel, steady, and at idle. Sometimes at idle it dies. I changed the plugs and wires. I also tested each plug pack (can't think of the real name). They operate between 0.4 - 0.8 ohms. Well they are all in range. And something was arcing under the fuel rail when the ignition was in the on position but not running.
Any ideas, suggestions? I am pretty sure it was water related. But now that the car is dry, it is still messed up.
dvmotorsports is offline   Reply With Quote
Old 04-12-2006, 01:26 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
well to be honest the minute you said power wash,, i thought uhoh.. ECU is soaked.. check your computer dude. it might have water in it
Old 04-12-2006, 01:58 AM   #3 (permalink)
vwk
vwk is an unknown quantity at this point
^^^ what he said. Caught me after having my 328is for only 4 hours...
Open it up, clean everything you can see (corrosion) with a small toothbrush and then reseal the ecu.
Also check if the soft cover that is in front of the computer is placed right, there is a small edge of iron you have to slide the cover in.
If it's torn, replace it.
The problem is caused by somewhere near the window, in the plastic cover. Dealer told me it's caused by the nut plugs that hold it.
Euro E36 M3 3.2 Rebuild Project
27 years
vwk is offline   Reply With Quote
Old 04-12-2006, 12:29 PM   #4 (permalink)
I thought the ECU was in the passanger side floorboard? Am I mistaken? Oddly enough, the car ran fine this morning. So it had to be water. But what ECU are you talking about?
Old 04-12-2006, 01:33 PM   #5 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
ECU behind the firewall int he passenger side of the engine bay. It's a common problem when peopel get their cars washed.
Old 04-12-2006, 03:58 PM   #6 (permalink)
oh, my ignorance i guess. thought it was located elsewhere. thanks guys.
Old 04-13-2006, 10:12 AM   #7 (permalink)
zebrex is on a distinguished road
do this now I can go to any car wash I want
http://forums.bimmerforums.com/forum....php?p=5552421
zebrex is offline   Reply With Quote
