| Needs help, car wont start! I have a BMW Alpina B3 3.0 (the equivalent of a 325) and it won't keep on running for some weird reason. I was away for the long weekend came back was about to do an oil change and boom...the car start and dies...
It actualy starts and then stops just after 2sec to idle...if I press the gaz it sounds like it was running on 3-4 cylinders with nice little explosion noise (like puffs of air coming out) i check the coils all seems ok (0.5 to 0.7 resistance on each) Change the spark plug (maintenance was needed there) and the Valve cover gasket as it was leaking into the sparkplug tubes. It almost sounds like it wasnt getting any gaz in some cylinders...could it be related to the fuel filter or the injectors? |
