Need To Remove Differential Bolts - BMW Forum - BimmerWerkz.com
Old 11-15-2004, 12:17 PM   #1 (permalink)
93 325i's Avatar
Tried all over looking for the hex socket to remove the final drive fill & drain bolts but cannot find it anywhere. The book says it is either 14mm or 17mm. Does anyone know what it is on a 93 325i without limited slip? Have to get it online but not sure what size to get
Complete mod list and pics:
My 1993 325i
Old 11-15-2004, 01:27 PM   #2 (permalink)
supark is an unknown quantity at this point
14mm
supark is offline   Reply With Quote
Old 11-15-2004, 01:38 PM   #3 (permalink)
93 325i's Avatar
thanks! would you believe the socket costs $15..
My 1993 325i
Old 11-15-2004, 01:58 PM   #4 (permalink)
Speedy-325is's Avatar
GO TO HOME DEPOT AND BUY A SET FOR $20.......dude u dont buy tools online!!!!! but them from a store and they will be guaranteed for life!!!!!! MEN BUY TOOLS!!!!!
its not a one use kinda item!!!!! SEARS has great tools!!!!!! .....GO BUY SOME!!!!
Old 11-15-2004, 03:37 PM   #5 (permalink)
93 325i's Avatar
i went to 2 different sears' stores and a home depot plus numerous autoparts places- the largest hex socket was 10mm....even at sear's the allen wrench keys jumped from 12mm to 17mm- there was no 14mm key even..let alone socket.. BTW i do have tools but not hex sockets- which i would be willing to buy at a store but around here the largest readily avaliable size is 10mm
My 1993 325i
Old 11-16-2004, 12:35 AM   #6 (permalink)
You may have a hard time fitting a hex socket in there - a cheap alternative to buying the $15 dollar socket is to get a 14mm allen wrench (about $5), cut off a portion of it, and stick it into a 14mm socket - that way you can allow it to fit in the tight clearance between the spare tire housing and the differential.
Old 11-16-2004, 07:49 AM   #7 (permalink)
93 325i's Avatar
Good point. I was checking out the 2 bolts and the top (fill) bolt has about 3 inches of clearance to the spare tire housing. 1/2 drive hex should fit tho. If not i can always cut down the hex socket right?
Edit- Second thought, I think i'll try and make my own. Why not save $10..
Thanks Supark
My 1993 325i
how to remove front bumper on an e30? baram23 3-Series (E21, E30) 2 08-30-2004 06:41 PM
Mammoth e36 DIY El Presidente Audio and Electronics 0 06-24-2004 01:02 AM
Differential Service Bulletin roloson M-Series (M1, M3, M5, M6) 0 01-06-2004 06:02 PM
Slave Cylinder Bleeding Help BmWNoobie 3-Series (E21, E30) 5 12-13-2003 07:32 PM
