Need help with Rear Window not going up sometimes... - BMW Forum - BimmerWerkz.com
Old 08-24-2006, 10:42 AM   #1 (permalink)
bimerguyCW is an unknown quantity at this point
Unhappy Need help with Rear Window not going up sometimes...
The rear pass window of my '93 e36, 325i has an intermittant problem that involves the window UP control only. The window will go down anytime its up but when down and trying to go back up it will not and they days later it will.
Also, when it won;t go UP I don.t hear any click or interior light dimming like when the DOWN button is pressed.
I checked the voltage at the plug to the motor by unplugging and checking volts and get +12v for each window button click(UP & Down), so voltage is getting to the motor. The motors resistance is around 1 ohm.
Does this mean the motor is bad/weak or does it have some kinda thermal protection that has to reset vefore I can use the UP button?
Do I have to replace the motor AND regulator arms if it is bad?
Thanks for any advice.
bimerguyCW is offline   Reply With Quote
Old 08-24-2006, 01:18 PM   #2 (permalink)
Alvarez_7 is on a distinguished road
have you made sure everything's well lubricated? if it isnt, it will make the motor have to work harder and perhaps make it not work as good.
Alvarez_7 is offline   Reply With Quote
Old 08-25-2006, 12:32 PM   #3 (permalink)
That's a good point...What's the motor resistance spec
I'll check the glides and teeth of the regulator.
Old 08-25-2006, 12:42 PM   #4 (permalink)
From both switches?
Is the problem occuring when you use either switch? (the one at the door, or the one on the console?). Could be just a dirty switch, since you don't get the dimming dome light effect. Try some CRC electrical contact cleaner or swap switches on the console and see if the problem moves with it.
Mike
Hamfisted is offline   Reply With Quote
Old 08-30-2006, 10:30 PM   #5 (permalink)
Not the switches, I swapped them and no changes.
I guess the motor is weak/bad and I can get a new one for $78 w/ CCA discount from the stealer.
I hope it's not to had to swap since the regulator will be dis-assembled, right?
Any advice on the motor swap and regulator handling?
735 1998, rear window roller blinds phil 1,6,7,8 - Series and Mini Cooper 3 02-08-2011 05:02 AM
e36 rear right window qwfx 3-Series (E36) 4 02-10-2006 11:16 PM
used 528: rear window & cam belt question jcmky 5-Series (E12,E28, E34, E39, E60) 1 10-16-2005 04:37 PM
Very Hot Spot On Wagon/touring Rear Window nv325xiT 3-Series (E46, E90) 2 01-25-2005 03:16 AM
Rear power window failure Minardi 5-Series (E12,E28, E34, E39, E60) 2 08-14-2004 01:23 AM
