Need Help please - BMW Forum - BimmerWerkz.com
post #1 of 9 (permalink) Old 10-08-2009, 11:59 PM Thread Starter
beebedl is on a distinguished road
Need Help please
I have a 1997 328i,
I was experiencing rpm spikes and the transmission would randomly sometime go into safe mode. When the transmission was in safe mode i took it to get the codes pulled and it came back with 4 solenoid codes and torque converter clutch speed monitoring code and ODBII code of P0720(output speed sensor) since then the car will not go out of first but rather right into safe mode after 1st gear. Just yesterday i found a vacuum hose broke and fixed it.however no fix on the transmission. I can drive the car fine in all gears using the manual setting. What could this all lead up to or what should i try?
beebedl is offline
post #2 of 9 (permalink) Old 10-09-2009, 12:05 AM
Ich bin der Modifikator
johnnyBgood's Avatar
johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough
Originally Posted by beebedl View Post
I have a 1997 328i,
Do you know when it last had a trans service? Filter & Fluid Replaced?
____________________________________________
johnnyBgood is offline
post #3 of 9 (permalink) Old 10-09-2009, 12:09 AM Thread Starter
about 7k miles ago
beebedl is offline
post #4 of 9 (permalink) Old 10-09-2009, 12:12 AM
about 7k miles ago
Ok.....
other then the trans codes, are there any check engine codes.....?
jb
post #5 of 9 (permalink) Old 10-09-2009, 12:13 AM Thread Starter
yea the check engine code is the P0720 (output speed sensor)
beebedl is offline
post #6 of 9 (permalink) Old 10-09-2009, 12:27 AM
Found this:
http://www.europeantransmissions.com...4HP24_diag.pdf
& this
http://www.ebooksquad.com/2009/01/05...diagnosis.html
post #7 of 9 (permalink) Old 10-09-2009, 09:18 AM
Quoted: 1 Post(s)
If you can shift through all the gears fine in manual mode, the transmission is still working correctly. More then likely it is an issue with the trans computer or even just the speed sensor.
FCP Groton
877-634-0063 |
- European Car Parts Specialists
- Import Replacement Car Parts
FCPGroton is offline
post #8 of 9 (permalink) Old 10-09-2009, 11:18 AM
Help from over the pond
marti5's Avatar
I would also say its the speed sensor, now on mine there are two input and output and they are located inside the tranny, you have to drop the pan, so drain the fluid 1st, then you will see the valve control body this is where they are situated, easy to remove.
But I would say check at RealOEM.com Online BMW Parts Catalog to make sure they are in the box as some I know of you can retrieve them from the outside.
marti5 is offline
post #9 of 9 (permalink) Old 10-30-2009, 10:01 PM
joseluisbaez is on a distinguished road
Transmission solenoid
I have a 1997 328i,
Transmission solenoid can go bad. That is what makes tranny shift. Lucas oil makes a chemical that frees up solenids in the tranny, easy to use as long as tranny is not sealed, if sealed you may have to change solenoids, but check with dealership to insure you are changinging the right parts...Good Luck
joseluisbaez is offline
