Need Help Identifying a Hose Leaking Coolant - BMW Forum - BimmerWerkz.com
Old 11-10-2012, 05:08 PM   #1 (permalink)
BMWBreaker is on a distinguished road
Hi fellas, I'm not too mechanicly inclined as most of you, with that being said my 95 318ti is keeps overheating. I found the topic to bleed it and fix the airlock but it is actually leaking coolant and keeps overheating when the car sits running. I found the source of the leak at the driver side- there is a hose that from behind the radiator to the outside up. One end appears to plug in a type of swith on the back end. It is a hose with a flat c shaped wire inside. On the front end the hose transforms into a hard wire and runs staight up. Any ideas what the hose is called or if it's easy to remove to fix. I apperciate anyones time. Thanks!
BMWBreaker is offline   Reply With Quote
Old 11-10-2012, 07:20 PM   #2 (permalink)
ZenitramNaes is on a distinguished road
You should take a picture. You'd have an answer a lot quicker.
Sent from my iPhone using Autoguide.com App
ZenitramNaes is offline   Reply With Quote
Old 11-10-2012, 09:10 PM   #3 (permalink)
Here are the best pics I can come up with. Still leaking apparently after being on a jack stand for 5 hours.
Need Help Identifying a Hose Leaking Coolant-pic-2.jpg   Need Help Identifying a Hose Leaking Coolant-pic-3.jpg   Need Help Identifying a Hose Leaking Coolant-pic-4.jpg   Need Help Identifying a Hose Leaking Coolant-pic-5.jpg   Need Help Identifying a Hose Leaking Coolant-pic-6.jpg
Old 11-11-2012, 04:43 PM   #4 (permalink)
problem solved. Wrong wire , just appeared to be leaking. Radiator hose had pressure cracks all through it leaking air/coolant. Easy fix but still slightly smoking.
Coolant Caking On Radiator Hose Risiko 3-Series (E36) 3 08-01-2009 04:23 AM
coolant leaking MaClaud10 3-Series (E36) 4 09-10-2008 06:06 PM
Replacing A Coolant Hose BYOCOM 3-Series (E36) 3 04-21-2005 03:55 AM
Coolant Hose And Brake Pop? silver328is 3-Series (E36) 5 10-01-2004 06:36 PM
Coolant Hose Diagram? M5power 5-Series (E12,E28, E34, E39, E60) 0 03-21-2004 11:36 AM
