Need Help with the Fuel level......Please.... - BMW Forum - BimmerWerkz.com
Old 01-12-2008, 05:39 PM   #1 (permalink)
hyper_cool is on a distinguished road
Exclamation Need Help with the Fuel level......Please....
Hi Guys,
Thanks in advance for the help. For some reason my e36 318i car started showing lotsa problems after almost hitting 200K clicks. I'm just wondering if someone can point out on what's wrong with my car. The cluster indicates I have empty fuel and the orange light stays on. I thought my tank was empty so I went to gas station and got it filled but the fuel level still stays at empty position. I tried the cluster test by holding the Trip button and putting the key to On. All of the gauges moves properly including the fuel gauge. Could this be the fuel level sensor? Has anyone here experienced this? I'm putting some time on my car and doing the maintenance since it's hitting 200K. Please help. Thanks.
hyper_cool is offline   Reply With Quote
Old 01-12-2008, 05:44 PM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
... your fuel sender went out..... happend 2 me this is an e30 correct? if so it is under the rear seat under a panel.....
1992 318i Coupe parts car
I am Captain Obvious
Old 01-12-2008, 05:47 PM   #3 (permalink)
Exclamation
It's an e36. Is this the same for E30 as well? Lol my baby is giving me head ache man. I replaced the alternator today and now it might be the fuel sender??? Is the sender part of the fuel pump as well? Thanks.
Old 01-12-2008, 05:56 PM   #4 (permalink)
... I think it is part of that assembly I think it is under the rear seat as well but im not posative because i don't own one.....
Old 07-18-2008, 01:22 PM   #5 (permalink)
Car: 1992 BMW 318i
johnnyb_s is on a distinguished road
It is part of the assembly and is under the rear seat. There are two- one on the right and one on the left.
Check the resistance at the leads for both fuel sending units using an ohm meter. If there is no resistance, one of the leads probably broke off from the sending unit. Remove the sending unit and solder the lead back in place.
Reset your gauges by holding in the odometer reset button while turning the key to the on position. Continue to hold in the odometer reset button until the needle goes up and then back down. Problem should be solved.
johnnyb_s is offline   Reply With Quote
Detroit '08 Preview: BMW does diesel, will show US-spec X5 xDrive35d and 335d administrator BMW News 7 01-06-2008 12:40 AM
Fuel Level Sending unit Bear 3-Series (E21, E30) 2 03-20-2006 05:23 AM
1983 320i Fuel Tank Level Sending Unit *wanted eat_mor_chikin 3-Series (E21, E30) 0 10-06-2004 12:32 PM
