need help before i kill my car - BMW Forum - BimmerWerkz.com
post #1 of 16 (permalink) Old 06-24-2004, 11:20 PM Thread Starter
cervasa is an unknown quantity at this point
alright heres the deal i have a 92 325i and ever since i bought it the car has had this problem when it reached the top of the blue line when warming up it would start to stumble and feel like it wanted to cut out but now its graduated to anytime the car is not at freeway speeds it is intermitent but it can get very bad so far i have had the vaccum lines checked nothing wrong there i have replaced the maf sensor no change oxygen sensor twice, fuel pump , fuel filter,spark plugs,oxygen sensor relay and still it continues its throwing codes for oxygen sensor, oxygen sensor relay, and the heater relay and the mechanic is saying that its probly not the oxygen sensor that is the problem but i dont belive anything he says now................anyone got any ideas or had this problem before??????????
cervasa is offline
post #2 of 16 (permalink) Old 06-25-2004, 12:33 AM
Kevin325i's Avatar
What type of spark plugs are you using?
Kevin
Kevin (President TBEA)
Kevin325i is offline
post #3 of 16 (permalink) Old 06-25-2004, 12:50 AM
BMWL2's Avatar
BMWL2 is an unknown quantity at this point
Send a message via AIM to BMWL2
try having the injectors cleaned
Motovated Motorsport Forums
BMWL2 is offline
post #4 of 16 (permalink) Old 06-25-2004, 01:06 PM
PhunkDJti is an unknown quantity at this point
try cleaning out the ICV (idle control valve) see if that helps.
PhunkDJti is offline
post #5 of 16 (permalink) Old 06-25-2004, 11:56 PM Thread Starter
bosch double tip plats i was noticing alot of people said not to use them i think im going to switch to the bmw ones went and bought some today...and where exactly is the idle air control valve at???????
cervasa is offline
post #6 of 16 (permalink) Old 06-26-2004, 12:11 AM
Been here a while.
97alpineM3's Avatar
97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all
You said you replaced your O2 sensor.... and the relay.... which O2 sensor did you replace... you know you have more than one right????
1997 E36 M3 1990 E30 325i
97alpineM3 is offline
post #7 of 16 (permalink) Old 06-26-2004, 12:23 AM
Kevin325i's Avatar
I think your problem lies within the spark plugs. Mine ran like shit with anything but OE. Swap them then let us know.
Kevin
P.S. I thought 92s only had a single O2 sensor after cat.
post #8 of 16 (permalink) Old 06-26-2004, 12:39 AM
clubin's Avatar
clubin is an unknown quantity at this point
You're gonna outrace your own car?? When you figure out how to do that, I'll be the first to tell you, "nice suicide."
*is almost certain he is the only one that understands what he's writing*
DISCLAIMER: I don't yet actually drive a BMW. Currently, I proudly drive a '93 Volvo 940, the inspiration for my love of RWD cars.
clubin is offline
post #9 of 16 (permalink) Old 06-26-2004, 09:24 AM
Scarface's Avatar
Scarface is an unknown quantity at this point
Send a message via AIM to Scarface
When driving, does the car sputter very badly and big loss off hp occur? A year ago, mine did, anything below like 3k rpm was fine but when it got above that it would instantly start sputtering all the way...Come to find out, my spark plug boots were corroded, was pretty cheap to replace, I think for the parts and the couple hours they spent trying to figure it out I spent around $100. Maybe have him check that, if thats the problem you are coming out cheap!
-1998 BMW 540i6(Axis Penta 20's,M5 shadow grilles,trunk lip,led tails,oem front lip,PIAA lighting)
-2002 Cadillac Escalade(Zinik Luina 22's,OEM HID upgrade)
Scarface is offline
post #10 of 16 (permalink) Old 06-27-2004, 12:28 AM Thread Starter
changed the spark plugs today and put in some injector cleaner for about five min. it was reving up and down spitting out chunks of carbon after that its run perfect ....still got the check engine light though as far as which o2 i dont know i have a feeling they repalaced the same one each time im going to have to look in to that and the spark boots to they looked a little dirty thanx for the help so far
cervasa is offline
post #11 of 16 (permalink) Old 06-27-2004, 12:30 AM Thread Starter
it was only sputtering at light load when i hammered it, it would drive pretty close to normal
cervasa is offline
post #12 of 16 (permalink) Old 06-28-2004, 09:40 PM Thread Starter
never mind its still sputtering but only when the check engine light goes off now...anymore ideas???
cervasa is offline
post #13 of 16 (permalink) Old 06-29-2004, 08:11 AM
Scarface's Avatar
I would definately check the connection inside the boot to see if anything is corroded, that sounds like what mine did...
Scarface is offline
post #14 of 16 (permalink) Old 06-29-2004, 08:50 AM
amancuso is an unknown quantity at this point
I'm still with most guys, stock plugs and CLEAN the IAC valve.
-Al.
<img src='
amancuso is offline
post #15 of 16 (permalink) Old 06-30-2004, 12:17 AM Thread Starter
boot as in trunk????? and where is the idle air control valve???
cervasa is offline
94 m-technic in AZ adamsbomb Cars For Sale 8 12-15-2005 12:43 AM
Chip Made My Car Slower gonzonick 3-Series (E36) 12 10-25-2005 03:46 PM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 09:08 PM
