| need help asap... low beam wont work on driverside... ok i bought the depo glass headlights the thing is the passenger side works perfect, angel eyes high beam and the hid low beam. when i put the driverside in the high beam and angel works perfect just the low beam hid wont work. the wires use the ballast to function so tried two different ballast and same problem so i hooked a stock bulb and connector to the stock wiring harness from the car and still did not work the stock bulb. my car is a 98 m3 please if someone knows whats going on or can point in the right direction it would be much appreciated thankyou for your time... |
