Need Help Asap!!! - BMW Forum - BimmerWerkz.com
Old 08-04-2005, 05:21 PM   #1 (permalink)
92_325i is an unknown quantity at this point
alright, so my new taillights came today and i was installing them without a problem. got them in and was checking to make sure all the lights were functioning properly. one light wasnt working so i was playing with it and then there was a spark, like a metal to metal spark of something shorting out. as it turns out now the brake light, tail lamps, front parking light, and drivers window doesnt work at all. the passenger side lights all work fine, as do the passenger windows and rear drivers side window, and so do the front turn signal and fog light and headlight, and the rear turn signal and reverse light. i am very confused and i need to fix this ASAP. i need help!!!
<a href='http://www.cardomain.com/id/jordan92bmw325i' target='_blank'>My 1992 325I</a>
<a href='http://www.cardomain.com/memberpage/461648' target='_blank'>My 1989 Nissan 240sx</a>
<a href='http://www.cardomain.com/member_pages/view_page.pl?page_id=724529&cat=10&val=1&page=1' target='_blank'>My girls' 1998 Camaro</a>
92_325i is offline   Reply With Quote
Old 08-04-2005, 05:28 PM   #2 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
kestrel325is is an unknown quantity at this point
Have you checked the fuse panel yet?
kestrel325is is offline   Reply With Quote
Old 08-04-2005, 05:30 PM   #3 (permalink)
yes. i'm not that stupid. i even replaced every fuse i could with new ones to see if that solved anything. but i was looking for something along the lines of a relay to check or something in the wiring and such.
Old 08-04-2005, 05:35 PM   #4 (permalink)
Okay...
Another culprit for you could be the comfort relay. This could be the cause of your window problems.... Finding the comfort relay
You said you heard a pop. Did you see (or smell) anything odd after that?
Old 08-04-2005, 05:39 PM   #5 (permalink)
i know about the comfort relay. that isnt the problem. only the drivers window doesnt work. the other three work just fine. and this didnt begin happening until the issue with the taillight. and i said there was a spark. i never said anything about hearing a pop or anything along those lines. there was a spark like you would see if something just shorted out. it took out the drivers window, the drivers side taillights, drivers side brake light, and front drivers side parking light. everything else works properly.
Old 08-05-2005, 08:19 AM   #6 (permalink)
alright, so now both brake lights work properly. the one window, drivers front corner light, and drivers side taillights dont work still. anyone have any ideas??
Old 08-05-2005, 09:47 AM   #7 (permalink)
93 325i's Avatar
This happened to me when changing the license plate light. For me it was only a blown fuse. THe tailights run off seperate fuses (so if one blows you still have one working taillight). Various other stuff didnt work as well. You kind of took offense when checking the fuses was suggested, but i suggest you take your time and really look at them
Complete mod list and pics:
My 1993 325i
Old 08-05-2005, 09:56 AM   #8 (permalink)
the fuses have been checked multiple times. they have all been replaced as well. every one of them.
Old 08-05-2005, 11:42 AM   #9 (permalink)
93 325i's Avatar
hmmm.. so driverside front corner, tail, and window dont work. Fuses are checked and rechecked.. were any of the fuses blown? Cuz i have an A/c problem that reverts to a fuse. I found the blown fuse replaced it and the A/C still doesnt work.. Rechecked the fuse and it is blown again. A short keeps popping the same fuse. Mayeb the tails are shorting the fuse over and over again.. This all reverts to the tails since it happened when installing them. Check those over real close, possibly dissconnect them and test again.. this seems to be a hands on kind of problem to fix
My 1993 325i
Old 08-05-2005, 11:50 AM   #10 (permalink)
i have disconnected the battery, rechecked the fuses, and replaced the fuses i already replaced. the only blown fuse i had originally was for the A/C which doesnt even have a belt on it right now. i guess i'm going to try to hook the stock tail back on and see if that helps anything. any other suggestions are welcome.
Old 08-05-2005, 12:27 PM   #11 (permalink)
alright, so putting the stock tails back on didnt solve anything either. i am out of ideas unless someone knows of a relay i should be checking or something.
Old 08-05-2005, 01:25 PM   #12 (permalink)
93 325i's Avatar
if you can sit tight i will check my bentley after work or if someone else can help.. i was just looking over the wiring diagrams for fuses and relays and such and they are an excellent guide..
My 1993 325i
Old 08-05-2005, 02:03 PM   #13 (permalink)
that would be awesome. i just dont want to drive too much in the dark if they arent working. the last thing i need is to get pulled over.
Old 08-05-2005, 06:07 PM   #14 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
[snapback]367627[/snapback]
Hey i dont want to scare you, but if have replaced all fuses, checked everything that it shuld be checked and nothing works, i will tell you that most likely you have fried some wires on the car. Be ready to start puling some plastics to check the harness, and by this i mean checking each wire to make sure they didnt melt the insulation or damaged somehting else.
anyway let us know what you have found.
You are a BMW driver when you become part of the &quot;Ultimate Driving Machine&quot;
Fraude an Fahren
BMW &gt; Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Old 08-05-2005, 06:30 PM   #15 (permalink)
Dudesky_E36's Avatar
Car: Anthracite e39 530iA
Dudesky_E36 is an unknown quantity at this point
Send a message via AIM to Dudesky_E36
Okay . . entertain me here. I know this is weird, but check for chafing in the wiring harnesses by the tail lights and the ones in the trunk lid.
Dudesky_E36 is offline   Reply With Quote
Need These Parts Asap!!! VIEN46 Classifieds Sell & Buy 0 12-22-2004 09:32 PM
HELP ASAP!!! please respond WickedBimmer 3-Series (E36) 9 02-01-2004 04:59 AM
