Need Help/advice About My Ac/climate Control - BMW Forum - BimmerWerkz.com
Old 04-28-2005, 09:52 PM   #1 (permalink)
alexlikh87 is an unknown quantity at this point
Ok well I just got my 98' 328i, and the AC doesn't work and I don't really know why. The heater and climate control work, but it just doesnt blow cold air. I can't check if i have refrigerant or not b/c the compressor shut off and I can't check the pressure. Another problem I'm having is the climate control panel turns off sometimes, it just shuts off and gets black and you can't do anything about it, so I'm thinking the AC and this is linked. I've seen posts about replacing a capacitator on the board of the climate control comp, so I'm thinking I will try that first, but I'm wondering if anyone has experienced such problems or has any advice? thanks guys, any help is greatly appreciated.
alexlikh87 is offline   Reply With Quote
Old 04-29-2005, 08:23 AM   #2 (permalink)
kvadgama is an unknown quantity at this point
If you climate unit just turns off every now and then, I would replace the capacitor.
When the unit turns off, AC, AC compressor, blower fan etc is also turned off.
Once the climate control is functioning fine, then trouble shoot the AC.
When you say you get the heat, is blower fan working?
kvadgama is offline   Reply With Quote
Old 04-29-2005, 05:50 PM   #3 (permalink)
umm yes the blower fan works, if I turn up the fan it blows harder etc, the only problem is if i turn the degrees to like 60 it's still warm air.
Old 04-29-2005, 11:20 PM   #4 (permalink)
Also check ALL of ur fuses!
Old 04-30-2005, 09:12 AM   #5 (permalink)
xorbital0's Avatar
xorbital0 is an unknown quantity at this point
Send a message via Yahoo to xorbital0
I am Dealing with this problem too. I replaced the climate control unit, its brand new, but now, my AC dosen't wanna kick in. I am not sure if its a compressor problem, or a blower motor problem, or a simple fuse... Summer is coming up, and i'm not about to spend hundreds of dollars to fix it.....
xorbital0 is offline   Reply With Quote
climate control fan speed sanga 5-Series (E12,E28, E34, E39, E60) 4 06-02-2010 11:47 AM
Climate Control Rookie 3-Series (E36) 9 03-14-2005 11:51 AM
Need Advice On Control Arm Replacement RC-Atlanta 3-Series (E36) 1 03-02-2005 04:58 PM
Traction Control bigred318 3-Series (E36) 14 12-20-2004 05:47 PM
Control Arms, Bushings, or both? clmautz 3-Series (E46, E90) 3 07-08-2004 11:28 AM
