| use the preset numbers below the radio display, when you put the last digit in, press and hold that button until the radio turns on, if you put it in wrong too many times it will lock and you'll have to wait about an hour of on time before you can put it in again. if that doesn't work the guy might have given you the wrong code, you'll need to go to a bmw dealer and have them look at the serial number on top of your radio in order to get the code.
__________________ 2011 Mazda2
1990 Mazda Miata |
