Need an engine for '95 325iS - BMW Forum - BimmerWerkz.com
Old 02-27-2006, 02:27 PM   #1 (permalink)
utahprez is an unknown quantity at this point
All:
My 2.5L engine threw a rod at 125K. I need a reliable source for a rebuilt/remanufactured engine. Anybody have suggestions? Any help/suggestions would be greatly appreciated.
utahprez is offline   Reply With Quote
Old 02-27-2006, 03:18 PM   #2 (permalink)
tomctx's Avatar
www.bmrparts.com
www.bavengine.com.
Dude! What happened for it to throw a rod at 125K? These engines last over 200k with maintenance.
Old 02-28-2006, 03:28 PM   #3 (permalink)
My 18 year old son happened to it while the rest of the family was on vacation. I made the mistake of leaving the keys at home.
It is OK, just an excuse for me to upgrade the engine. Otherwise the car is cherry inside and out.
Old 02-28-2006, 03:31 PM   #4 (permalink)
tomctx's Avatar
Props to the son! Taking out theses engines is not easy. J/K. Try those two links. I haven't had any dealings with either, but I have heard good things from other forums.
Old 02-28-2006, 03:56 PM   #5 (permalink)
I spoke to a friend of mine (a factory trained BMW tech) and he said that most likely he didn't throw a rod. He says that the camshaft is made of steel that can distort a lot befor it breaks and he says that most likely my son downshifted from 4th into 1st thinking that he was hitting third. When this happens, the camshaft candistort up to 20 degrees before breaking and it is likely that the intake valve was still fully open when the piston was at TDC...a lethal combo. He says that is is not uncommon for this to happen.
I talked to Bavarian Motor Exchange and they are fixing me up with a long block performance rebuild.
Old 02-28-2006, 04:05 PM   #6 (permalink)
thekid's Avatar
What I would do is get a 96 engine and convert back to OBDI giving you some extra hp with all stock parts to start with.
Old 04-15-2006, 03:18 PM   #7 (permalink)
Retired administrator
triggrhaapi's Avatar
It's highly unlikely that the camshaft twisted. M50 camshafts are forged steel and hollow, which means they are both brittle and fragile. It is highly unlikely that they were twisted. It's rather much more likely that the valve floated (this happens at high RPM when the valvespring can no longer keep up with the rate at which the valve is being depressed by the camshaft and the valve stays open for longer than the desired duration, which can lead to very hard contact with the piston (keep in mind that the force acting on the valve must exceed the tension of the valvespring in order for this to happen, so if the valve made piston contact, it would be with a great amount of force) and that could very easily break the piston itself, shear the wristpin, cause the motor to throw the connecting rod, or any combination therein. the only way that the camshaft would cause the valve to be open at the wrong time is if the timing chain were to break.
Addicted to Speed Since 1997
Old 04-15-2006, 05:17 PM   #8 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
wat he said...
1992 325IS engine + tranny swap danyal711 3-Series (E36) 6 08-20-2004 12:57 PM
engine swap for a 1990 325is cdunn321i 3-Series (E21, E30) 1 05-19-2004 07:16 PM
